New-to-me Wd45 low rpm
OldManLarry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldManLarry Quote  Post ReplyReply Direct Link To This Post Topic: New-to-me Wd45 low rpm
    Posted: 10 hours 46 minutes ago at 11:11am
Good morning gentlemen.
I’ve had a friends WD45 sitting about the farm for a bit. I’d like to put it to work. Starts generally well. New carb, supposedly rebuilt engine.
It fails to maintain rpm while running. Bogs under load from 4’ brush hog in medium grass.
I adjusted the carb/governor arm linkage by bending. It was 3/16” off. While tractor is off, linkage sits just into the gov arm hole with carb at max input. Gov arm on hand throttle/gov body side sits fully engaged at max rpm. After starting, gov arm reduces rpm at carb, hand throttle does not increase rpm.
Can someone post pictures of the throttle side spring linkage, and the carb-side spring linkage? I believe they’re incorrectly installed.
Hand throttle is fully engaged about 3/4 of the way down, but gov arm on gov side is fully engaged for max throttle.
Do you gentleman know what may be the culprit here? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldManLarry Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 44 minutes ago at 11:13am
After shutting down tractor, carb and gov arm return to max throttle position.
There’s a large dent, watermelon could sit down in it, in the underside of the oil pan. I see oil lines running to the governor. Maybe there’s a correlation there?
Thank you sirs, I really appreciate your time and knowledge
Edited by OldManLarry - 10 hours 12 minutes ago at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 58 minutes ago at 3:59pm
Start with this: There CANNOT be ANY SPRING (on the carb side) connected to the governor arm, governor link rod or the carburetors throttle shaft. There SHOULD BE a spring connected to the CHOKE lever that goes to the engine's block drain cock. That is correct. Any spring connected to the governor/carb control on a WD-45 is WRONG. Until this is verified and/or corrected, everything else you do won't be right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldManLarry Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 52 minutes ago at 4:05pm
DrAllis, thank you. I’ll get that spring in the correct spot. It’s currently just dangling from the gov-carb linkage arm. I’ll check back in after
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldManLarry Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 28 minutes ago at 4:29pm
Choke plate spring is now connected, holding the choke closed except when choke is pulled. Thank you DrAllis.
The gov. Arm on the carb side still seems to me like it is restricting the rpm’s. Any other ideas? Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldManLarry Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 21 minutes ago at 4:36pm
With the hand throttle at the highest rpm setting, should the govenor arm/linkage at the carb be fully engaged against the carb pin?
