new to me plow |
Michael V (NM)
Topic: new to me plowPosted: 18 Mar 2026 at 1:01pm |
i got this with a couple WD's I bought at an auction here in NM. I studied the plow ID on the knowledge base, looks to me to be a WD-#53 pick-up plow,, best measurements I get it's a 14",, so I found an owners book on ebay,, looks like there is a lot of the adjustments are WAY off, first, the lift links are above the lift bar, next the pull bar and beaming adjustment are set too far to the RH side. I gots the adjustments soaking,,
What ya'll think?? ![]() ![]() |
560Dennis
Posted: 18 Mar 2026 at 4:20pm |
that is the hot set up .
Dave the plowman specializes in snap coupling plows .
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 18 Mar 2026 at 4:28pm |
Someone may have had that plow hitched to a D17 which would need longer lift links to not have the hitch hitting the bottom of the transmission case when fully lifted.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3124 |
Posted: 18 Mar 2026 at 4:44pm |
That's nice. It was coverboards and moldboard extensions
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 328 |
Posted: 18 Mar 2026 at 4:48pm |
The lift links need to be flipped over a half a turn on the hinge area. The bottom needs to be inside the U part. Andy
wjohn
Posted: 18 Mar 2026 at 6:17pm |
I have never had any luck soaking stuck plow adjustment threads... straight to the torch for me! However, being in your climate maybe you will get lucky? Definitely a 53 and a good save.
Michael V (NM)
Posted: 18 Mar 2026 at 7:43pm |
Well,, John,, as rusty as this one is,,, it didn't come from NM...I'm sure the torch is gonna be the final answer....but,, I'm gonna give it a try...
Then,, gonna hafta spend a lot time with a grinder and flapper to shine up them moldbards.. Dave,, yea,, gots some nice 'extras',, be cool to find some jointers.. Edited by Michael V (NM) - 18 Mar 2026 at 7:46pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Posted: 19 Mar 2026 at 7:21am |
Good luck with the plow Michael!
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 124 |
Posted: 19 Mar 2026 at 9:08am |
After a couple rounds in rocky or sandy soil those bottoms will shine up.
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 19 Mar 2026 at 2:01pm |
Spent many hours with one of those. Both behind a WD and later a WD 45. We plowed square fields in circles so the corners had to be rounded off-tough on the left brake. Hope you get it functioning.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8776 |
Posted: 13 hours 12 minutes ago at 11:29am |
Michael, something that I've always wanted to try on rusty parts such as that, is heating em up, then melting candle wax into the threads. I've heard of success stories doing that, why don't you give it a try and report back on how it works, lol.
Darrel |
Michael V (NM)
Posted: 2 hours 5 minutes ago at 10:36pm |
ok,,yea, I know some sandy ground will polish them plows quick. the pictures really don"t show how bad the rust really is....
plan is,, get the adjustments freed up, set the basic book settings, do the LH wheel on an 8" block,,then I gots to find a neighbor that will let me come play with my plow..all my farm ground has been planted back to grass,, and as dry and windy as it is around here,, I'm not plowing up anything,,, I've had enough blowing sand around here....
