New to me old 5020
arlon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arlon Quote  Post ReplyReply Direct Link To This Post Topic: New to me old 5020
    Posted: 18 Jan 2018 at 11:02am
Forgive me for I have never owned anything but a little garden tractor. I'm a decent gear head but fairly clueless about tractors.
That said, on an impulse I ran across what I think is a 1980 AC 5020 4WD tractor. It just really spoke to me and I bought it. Probably over paid but such tractors are much in demand here (Texas Hill Country). The 4WD has been disconnected because of a bearing issue. Has a loader (not factory) on it that works. Starts, runs, drives but looks pretty worn out.
I'm guessing that parts are going to be an issue but other than the bearing, everything else seems to function. I'm mostly looking to find out where to look for parts, decals and such if they are available at all. I'd like to fix the 4wd and just get it looking more presentable. I'd like to be able to park it in front of the shed instead of behind it. (-:}
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 11:12am
actually, that is an allis branded loader.  Model 430.  Have one on my 5020
Edited by alan-nj - 18 Jan 2018 at 11:17am
If ignorance is bliss, than happy days are here again.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 11:13am
in the on-line AGCO Parts Book you can find the parts breakdown for the 5020 FWD
http://www.agcopartsbooks.com/PartsBooksN/login.aspx
Just click on View Books as Guest User; no need to register,  then type in 5020
Whether or not AGCO has the parts would take some investigation or calls.
Also, if you have the old bearing out, there should be a mfg's part number on it which can be cross-referenced if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote arlon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 11:29am
It did come with a shop, operators and parts manuals too.
Loader looks like it had CAREY STANLEY (close) written on the side of it (very faint, painted over).
Edited by arlon - 18 Jan 2018 at 11:32am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 3:56pm
It is a Japanese built tractor made for Allis Chalmers.  The company which built them is no longer in business, so parts can be very hard to find.  A local print shop can make decals for you if you bring them the old ones to use as a pattern.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 5:08pm
Maple hunter decals of Indiana can fix you up on decals
Post Options Post Options   Thanks (0) Thanks(0)   Quote arlon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 6:54pm
Guy I got the tractor from told me the guy HE got it from told him it only needed a bearing and he had taken these shafts out. I was told the tractor runs fine as long as I don't put it in 4wd. Seems odd to me. I just wonder what all kinds of crud have gotten in there. One shaft looks pretty good but one is caked in dirt. Assume the dirty side is where the bad bearing is.
Steering is really loose, like half a turn of slop at rest. Are these issues possibly related? Slop seems to in the steering box as the steering rods don move at all where the play is.
May have gotten myself more than I bargained for. What a way to make a fun summer project!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 7:16pm
Google Hinmoto E series tractors, also MF 1020 is made by Hinmoto.  Nearly same tractor, not sure about parts interchangeability between brands.  I was tempted to go the AC 50 series fer a small asian tractor, but kuboters is plentiful, around here, and I got one that is a platform, not a step over the tranny model like the old AC's are.Wink
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 7:41pm
The front wheel drive was the problem on these. Hopefully it is just a bearing....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote arlon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 10:37pm
I assume the lever up is engaging the 4wd? I can only find 3 sentences on the 4wd operation in the operators manual and no mention of which way is which. Just telling where the lever is and to disengage it on hard surfaces. Up just seems logical and since mine is disconnected, I want to be sure nothing is turning in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2018 at 10:50pm
Is that a break in the small gear to the right ?
Edited by Gatz in NE - 18 Jan 2018 at 10:50pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 2:53am
Those fronts are problematic and no parts are available.I have a Massey Ferguson 220
its the same as an AC 5030 that had a torn up 4WD when I bought it, took the front end off a parts AC 5020
I have and turned it into a 2WD.If its only the bearings you can get those I think.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 5:04am
my guess is the bearing went bad and the ball bearings messed up the gears in the front.  if the steering is sloppy moving side to side it's probly the rubber bushings in the steering tube, if the steering wheel moves up then the pinion bearing is bad and or the snap ring left loose you need to replace it before the gears get wore out!
good machines, but parts are hard to find. I had no problems finding the bearings for the front inside the final drive.
edit: by the steering moving up I meen look under the steering wheel, is the wheel tight to the steering tube or can you see the steering shaft?
Edited by dt1050 - 19 Jan 2018 at 5:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote arlon Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 8:53am
No, just part of a mud dauber nest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2018 at 6:05pm
Don't fergit to check fer a loose nut behind the wheel...Wink
bbridgman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbridgman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 2:43pm
Do you still have the shafts with the u-joints and linkage that's in your picture?
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 8:45pm
Hello Arion    I haven't tried this # yet  Hinomoto Southern Global parts 601 928 2491
  Good luck
