New addition to the herd.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: New addition to the herd.
    Posted: 16 Aug 2026 at 6:53am
Thought you guys might like to see thjis;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 8:04am
I'm not standing next to it, but is that original paint?? Pretty good looking tractor I'd say. Just like the one my Dad had except for the air conditioning. They are a really nice cab even tho not an Acousta cab. The 38 inch rubber gives you a much more acceptable road gear too.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 8:43am
Nice! Of all the ones I have, I lean towards the 200 as my favorite. A very nimble machine.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 8:43am
That's a big tractor in my book. It sure looks good!
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 5:26pm
You did good Mike, that's a nice looking tractor.
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2026 at 10:26pm
Good looking tractor in my book. At my age any tractor I’m going to spend much time on needs a cab with heat and air. Maybe that might mean I need to retire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 6:37am
I believe it is original paint. Getting attached to this thing already! Doesn’t show in the video but it has a new seat in it, big plus!
This one may just get used on a tractor ride or two. You know those mornings when it’s a bit cool. Or, if I get the air working, those days when it’s sweltry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 7:55am
How long did it take for you to like the throttle lever ???
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 10:11am
Nice! I can tell by the PTO shield its dual speed. Is it hyd. or manual engage? Year model? Hopefully it's a 74/75 with gated PD control. 2 things I would have to do first: drill rivets out of grill screen, remove screen and clean it up and paint and re-install with brass screws that won't rust. Then straighten muffler and paint with at least 2 coats of some good hi-temp paint. You'll be amazed at how better it will look. Fix the clutch and get the AC working and you will love the old gal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 10:38am
Back in 1975 I made an adapter to be able to install a 5 inch chrome exhaust pipe on Dad's new 200. The large diameter and 48" long (?) tube makes a 301 sound bigger than it really is !!!!!  and fills in the large hole in the hood.
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 5:01pm
IBWD Mike
Great looking tractor
Congratulations
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2026 at 9:07pm
Nice tractor Mike, you’re gonna like it once you get the clutch repaired. Looks to be in great shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2026 at 5:55am
Thanks guys! Yes, the controls are easy to like, very easy. Serial No. 5706 which Tractor Data shows as a late 73 model. It’s going to move into the shop at some point in the near future. Then I can start fixing on things. Have to move several others around to get it where I want it for the split.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 5:35am
The muffler has been taken care of. Grill is waiting, trying to get the combine ready to go now.
Edit; I meant to quote KyAllis.
Edited by IBWD MIke - 12 Sep 2026 at 5:36am
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2026 at 8:00am
Where did you find that? It looks really nice. My dad had one very similar to that with 38s and factory air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 32 minutes ago at 5:16am
That's an interesting story. Was getting hoses made at Ziegler Cat, must have had an AC hat on. Builder asked if I'd be interested in an AC tractor. Said possibly. Took a few months but eventually got a deal made. Tractor was near Milo Ia.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 44 minutes ago at 6:04pm
IBWD Mike, congratulations! Your 200 looks like a very fine addition to your herd. Definitely AC’s premier turboed 301 tractor for its 100 series? It’s OEM paint is still looking good. Maybe a good rubbing compound followed by a wax job would bring out more luster,, or not?? It’s cab’s AC/heat is great too.
