Need Help-D-21 hydralic pump |
b170dr ![]() Bronze Level ![]() ![]() Joined: 05 Feb 2012 Location: Gays Mills Wi Points: 46 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Apr 2012 at 5:56pm |
The bottom driven gear with the spines. Gear 11/16 wide. Is it the same gear as 190. The gear that it splins into has same parts number as 190. But the bottom driven gear has a differnt parts number. I need the driven gear. If anyone can help, would sure appriate. Thank you, Roger |
'64 B-10, '58 D-14, '60 D-15D, '58 D-17D, D-19, 170, 2-185D, 190, 68 D-21 11, 72-220, 7000,7030, F-2 G,w/5 Heads,L-2 G, 330 No-Till
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21957 |
Not sure I understand your description. If this is a triple section pump (3-point hitch and Traction Booster) the front pump gears top and bottom (lifting section) are different (wider) than a 190. The middle section gears top and bottom (traction booster section) are the same as a 190. The rear section top and bottom (power steering section) are the same as a 190.
