Need help with D-17 |
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1034 |
Topic: Need help with D-17Posted: 01 Feb 2010 at 10:02am |
I have 1963 D-17 ser.3 and need to replace O-rings on power director shaft that the shift lever attaches to.Can I do this sliding the shaft one way to replace one O-ring and then slide it the other way to replace the other O-ring or do I have to remove the side plate on right side of tractor? any help would be really appreciated. Thanks !!!
Austin(WI)
Joined: 11 Sep 2009 Location: Wisconsin Points: 1462 |
Posted: 01 Feb 2010 at 10:40am |
There are woodruff keys that fit in this shaft...I think you will have to removed the side cover...chances are they will fall out if you move the shaft. Otherwise that should work. Good Luck |
"Better By Design"
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7539 |
Posted: 01 Feb 2010 at 5:25pm |
That's the best way to do it.
