Need help with 3 point on 8030
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: Need help with 3 point on 8030
    Posted: 30 Dec 2016 at 4:54pm
Added a 3rd remote to my 8030. All 3 remotes work fine - but 3 point won't raise. What did I mess up?
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:16pm
By chance the draft lever got pushed all the way down during the process?
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 6:33pm
No action no matter whether draft is up or down.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:15pm
Will it raise if you reach behind valve and push in on spool?
Did you remove the valve assembly or just add a valve?     MACK
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2016 at 9:23pm
Did not remove the assembly - just added a valve. Did not try moving the spool by hand - did check and confirmed that the lever was moving the spool in - at least some - although it did not seem like it moved it very much. Will try moving the spool by hand in the morning.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:10am
The spool does move - but not as much as on my other 8030. The 3 point lever also creeps forward - so there must be some residual pressure - I'm guessing hydraulic rather than mechanical. I am also getting an intermittent hydraulic filter warning light that was not there before adding the 3rd remote. Is there a check valve of some kind in the 3 point valve? And can I get to it without taking the stack off?
This page was generated in 0.107 seconds.
