mold board plowing
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: mold board plowing
    Posted: Yesterday at 1:27pm
So my 96 year old Dad passed away over the weekend so
I'm at home this week and trying to distract myself some by
watching plowing video's.
Dad and mom had 70 acres when I grew up and about half
of that was tillable,we had a massey harris 44-6 and a 53 ford
jubilee and as a kid I was in my glory driving them.
In high school I took AG mechanics and one thing I remember
was the teacher telling us one time that when a mold board plow
was set right the tractor wouls stay in the furrow on it's on.
I see a lot of guys that look like they're fighting to keep their
tractor in the furrow,what are some of the reason's for that,just curious.
Sorry to be so long winded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:54pm
The main reason I will give to answer your question is: No-till came around in the very late 60s early 70s. So that makes most of us that actually plowed for everything very near 70 or above. I myself always enjoyed plowing and as our farm never had BIG POWERFUL tractors, I learned real quick (from my elders) that small adjustments made big differences in ho easy a plow would pull. My grandfather used horses to farm until sometime after WWII. It was probably sometime in the 50s before  he could buy even a used tractor. I remember when I was 11 or 12 and my grandparents came to the field to pick me up where I was plowing ( thought I'd been doing a good job as I'd not touched any adjustments) and my grandfather walk over and moved the furrow lever a click and said make another round. The tractor quit lugging so hard. When I asked him to explain what he did, he said the plow was not level.
  I see in most of the videos, the plows are nosed in and leaning left. Most likely due to worn parts and lack of knowledge, but they are rooting around like a bunch of hogs as Grandad would say.
  I've attended many "Plow Days" where that is the case. Very few place actually have individual areas for each person. Following a poor job, results in a poor job.
  The last on I took a tractor and plow to many had shins worn the to frog and a few were trying to plow with broken shares. After a couple rounds I could bear to watch the hogs so I loaded up.
 On our farm we NEVER NoTilled and plowed everything and payed attention to the lay of the land on how the rows ran instead of just using the longest fenceline.
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:47pm
Sorry to hear of your loss. Would love to see pictures of the 44-6. They didn't pull as well nor have the power of the regular 44's with the Continental 4 in them, but they sure had smooth power. Great for sawmill/belt work.
I've admittedly been in that situation fighting the plow a few times. I know how to set a plow, find the centre of draft, etc. But with much of our land at our Northern farm being so steep, we typically have the wheels set quite wide for stability. Often when I go to plow I think to myself, "it's just a few acres: With enough front weight I'll just fight it and get it done because the time it would take to adjust the wheel spacing isn't worth it for only a few acres". Half the time time I get part way done and get fed up fighting it, so I stop and adjust the wheels to pull at the correct centre of draft.
One problem for us is that our hills are dangerously steep in many areas, and when you're plowing you have to throw the furrow down-hill for it to turn. So it's already dangerously steep, then to compound the problem you have the furrow-wheel dropped a few more inches into the furrow, so it's even steeper. I've had a few close calls plowing. Dropped the furrow wheel into an unseen groundhog hole one time and three wheels came up in the air, stood there for a moment, then gently came back down. With land that steep I'll sometimes prefer to keep the wheels wide and fight it a little than lose any stability by narrowing them up.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:32pm
I've plowed until a few years ago. My Dad said that a fellow should plow with a horse and a plow for a day and then he would know how to adjust a plow properly which in my opinion is becoming a lost art. My last plow was a Kverneland vary-width which is the best plow built
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:05pm
The massey has been gone for a long time
and I have no idea where it is now,
but my brother still has the jubilee.
I know it can take some time to get plows
adjusted correctly but it sure makes a big difference
in the long run.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:29pm
Fighting to keep in the furrow is a force vector problem. Like driving a car that's out of alignment and just wants to head for the ditch.
There are a few YouTube videos. If you can find books from the 1930s on plow setup that could help, I have an old John Deere 1930s book on general equipment and it has a little section on plow setup.
My father plowed our clay farm with a Farmall 806 and five bottoms. I disked with that tractor. I've only plowed with the heirloom Ferguson TO35 and two bottom plow at my place. I keep thinking I should find a pull type plow for my WD. But after breaking sod for a new field I no-till from there.
It's helpful to have a spotter watch you drive the plow to make adjustments. Today, you can strap a phone camera to a tripod and be your own spotter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:57pm
3-point hitch plows require some adjustments that are different than snap-coupler plows.  I know none of the plows we play with today are new, but 40 to 70 years old. Certain parts must be in decent condition or you'll not be very successful plowing. #1. Land sides MUST be all there ( not missing or badly worn out/gone) to keep the plow bottoms wanting to go straight ahead and not swing to the left! !! Many of these may have to be fabricated out of mild steel, but trust me, a good condition land side is a MUST.  #2. Good sharp plow shares (lays). The shares have to suck the bottoms into the ground and stay there and that means sharp points to keep the plow from bobbing up and down while plowing.  #3. Now, we have the bottoms pulling themselves into the ground and land sides keeping them in a straight line. Next, the wheel tread on the tractor must be set correctly (both rear wheels) for front bottom width cut and it also makes the plow pull correctly when the wheel tread is correct.   #4. Lastly, the plow frame MUST be level front to back and side to side when in the ground fully at working depth. You cannot see this while sitting in the seat !!! You have to stop with the plow in the ground and get off and look. ***  Lastly, on my 4 x 14's fully mounted 70 series, I remove the right side sway block on the 3-point hitch of the tractor. This see's to it that the plow isn't trying to pull the front wheels of the tractor towards the plowed ground in a hard pull. This is a big deal when you compare to snap-coupler plows which allow swinging of the plow and steering of the tractor while plowing.     THREE things: sharp points/shares, great condition land sides and the frame LEVEL in all directions. That is a great way to start out. And if you think you can begin your play day with rusty moldboards?? you're seriously wrong. High speed electric wire brush them off as best you can and find a field of sand to start out with.
Edited by DrAllis - Yesterday at 6:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:11pm
Sorry for your loss.
Yes a properly set plow you can drive in furrow and not hold steering wheel. An operators manual helps setting plow up. But it’s easy to get lost making adjustments when just worn out parts is your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:40pm
Kevin,
Sorry for your loss of your father.  Sounds like he let you do some work on the farm. Probably a lot more than plowing. I don't know much about setting plows. But have plowed a lot of ground. Was I fighting the wheel. Humm cant remember that being an issue really? Did my dad have them already set? maybe? The Jubilee is a good tractor! Ours does most of the work around here. If you can get out and plow some this spring it will feel real good.
 Chris and Cheryl
dr p View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:41pm
Believe or not, when i went to cornell University a very long time ago, there was an agricultural engineering class that dealt with how to set up a moldboard plow. It was taught by a professor and the head of the field crop unit. Just to show off they took a three bottom trailer plow, set it up and then hooked a 50 foot chain to it and drove the tractor off 20 feet to the left so the chain was at nearly a 45 degree angle to the furrow. They started plowing and the plow stayed in the furrow the legth of the field.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:43pm
You also had to pass a practical farming exam. Now you can graduate with a degree in animal science and not know how to milk a cow.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 38 minutes ago at 10:26pm
Grandpa used to drive down to the creek and plow through a sandstone gravel bar.  Man they shined up purdy.
1952 CA13092
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 31 minutes ago at 6:33am
I can't contribute any knowledge to plow setting up, but evidently with a perfectly set plow, the tractor will steer itself along in the furrow as you suggest, because I've heard many plowing experts say that they had "auto steer" already back in the plowing days.
Darrel
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 16 minutes ago at 7:48am
Trying to follow…..so they pulled the plow with the chain? With the tractor way off to the side?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 13 minutes ago at 7:51am
I can get a plow going pretty darn good and when I turn the tractor over to my brother in law he can still do a horrible job! 🤣
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 24 minutes ago at 9:40am
Well I was by no means a plowing expert but I was always around
farming and Dad had 4 brothers and 2 of them also had farms so I
was around A lot of experience which doesn't necessarily mean
they knew it all but just a lot of experience.
So when out in the fields I did as told and plowing was one of those things.
I could always tell when an adjustment was made how the tractor changed
going through the field.I was a kid in all his glory back then.
Thank you all for commenting ,it's greatly appreciated and brings back
so many memories.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 20 minutes ago at 6:44pm
T bone, YUP
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 15 minutes ago at 6:49pm
I can get a plow going pretty darn good and when I turn the tractor over to my brother in law he can still do a horrible job! �£
There some guys that would break an anvil.
