Model K offset disc harrow? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10876 |
Topic: Model K offset disc harrow?Posted: 14 Mar 2017 at 7:55pm |
I have a model K offset disc harrow. It has a bracket broken-missing. It is the bracket that the transport chain hooks through. If someone has a disc and could be so kind as to make a sketch of bracket I would greatly appreciate it. The little arm that holds hyd hose is missing also. Easy to make if I had the dimensions. Thanks Tracy
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 15 Mar 2017 at 4:43pm |
How's this?
My hose bracket was destroyed
Tracy Martin TN
Posted: 15 Mar 2017 at 5:12pm |
Joe, that is much appreciated.What type of lift cylinder does yours use?I need to get one, and was wondering what size and travel they were. Thanks Tracy
Joe(TX)
Posted: 15 Mar 2017 at 5:19pm |
I has a factory tie rod cylinder with a stoke limiting valve. I'll try to get a photo and do some measurements.
Joe(TX)
Posted: 15 Mar 2017 at 5:42pm |
It looks like a 2 1/2 x 8 cylinder
Here a couple of photos. The close up shows the stroke limiter. ![]()
Tracy Martin TN
Posted: 15 Mar 2017 at 7:03pm |
Joe, again, I appreciate the help. Thanks Tracy
