Model B Stiff Rotation |
| Author | ||
TL73
Topic: Model B Stiff RotationPosted: 13 hours 26 minutes ago at 10:23am |
This tractor is a 38 and as you know hand crank only. Complete tractor was restored probably 15 years ago and has seen little use. To me, the hand crank seems much harder than expected. Even with the spark plugs removed the rotating assembly feels like it's way too tight. Even cranking it over with no sparks plugs shakes the entire tractor. I've seen people who can turn their engine over by rotating the cooling fan with the plugs removed. There is absolutely no way I could rotate this engine by turning the cooling fan. Is this normal?
| Sponsored Links | ||
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1014 |
Posted: 10 hours 55 minutes ago at 12:54pm |
How have you tried disengaging the clutch turning the engine over? If there is no difference you may have to remove the oil pan and plastigauge the bearings. I definitely this was the case with one B where the bearings were too tight, with correct clearances the problem was fixed and the engine turned over easy.
Joined: 11 Sep 2009 Location: illinois Points: 91060 |
Posted: 10 hours 42 minutes ago at 1:07pm |
did the tractor run after the rebuild ??? Has it been setting for a while ???
You could have some rust on the liners / pistons / rings causing things to drag.. If you KNOW the engine ran good at one time, i would put some penetrant or oil acetone mixture in each cylinder and let it set for a day or two.. Crank the engine over and push this out the spark plug hole... If it seems to help, you could drag the tractor around with the truck with the spark plugs OUT and in gear.... should loosen things up..
Edited by steve(ill) - 10 hours 41 minutes ago at 1:08pm |
TL73
Posted: 3 hours 19 minutes ago at 8:30pm |
This is what's odd to me. I'd been turning it over by hand with the clutch disengaged. I released the pedal lock and tried it with the clutch ENGAGED and it turned over easier. Maybe I'm missing something but I can't understand how the engine turns over easier with the clutch engaged. It's still stiff but significantly easier than before.
TL73
Posted: 3 hours 16 minutes ago at 8:33pm |
Yes, the tractor runs pretty good; we've been pulling it off until I can figure out why the hand crank is so stiff.
Edited by TL73 - 3 hours 14 minutes ago at 8:35pm |
Les Kerf
Posted: 1 hour 3 minutes ago at 10:46pm |
Could the throwout bearing be dragging on the bearing carrier? Is the linkage properly adjusted? |
