Main Bearing Sources
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Topic: Main Bearing Sources
    Posted: 09 Apr 2026 at 7:57am
Is there a source for main bearings comparable to Hastings for piston rings? When I had trouble finding rings using parts numbers, Hastings quickly matched the size I needed to their inventory. Now I'm having trouble finding mains for a JD tractor and wonder if there is a source for bearings comparable to Hastings for rings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2026 at 8:31pm
Mother Deere not supplying any more?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 21 minutes ago at 9:16am
The local Deere shop sent me to Deere forums and two local area businesses. Even after I pointed the pats department to the relevant page in the parts manual, they weren't able to help identify the part number, much less check for availability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 15 minutes ago at 9:22am
i have not tried this............
you could always call on the phone and ask questions...
Edited by steve(ill) - 22 hours 12 minutes ago at 9:25am
This page was generated in 0.180 seconds.
