Loss of power B |
ihscout
Joined: 12 Jul 2011 Location: Northern CO Points: 147 |
Topic: Loss of power BPosted: 15 Dec 2016 at 6:30pm |
My 40 B all the sudden lost a lot of it's engine power yesterday. It sounded as though the exhaust system is clogged somehow. I pulled the intake / exhaust manifold and found a couple of cracks in it. Welded those and reassembled. No change. Any ideas as where to go from here?
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 15 Dec 2016 at 6:50pm |
Is it hitting on all 4 or you missing spark on 1 plug. Check for good fuel flow at carb.
Randy WI
Joined: 22 Jan 2014 Location: Ogema, WI Points: 846 |
Posted: 15 Dec 2016 at 7:03pm |
check your air filter may have a mouse nest or some other thing plugging it up. Randy
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 15 Dec 2016 at 7:36pm |
I do not have all the particulars but usually when a tractor loses power under load my first suspect is - cheap, the condenser, more costly the Coil
Can't have my favorite not running well. Let us know how it goes. Good Luck! Bill Long
ihscout
Posted: 15 Dec 2016 at 7:57pm |
It is hitting on all 4 cylinders and the air filter is clear. I just put a newly rebuilt magneto on it this summer and have very few hours on that. It doesn't reach the higher RPMs as it did a day ago. Would the governor have anything to do with it?
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 998 |
Posted: 15 Dec 2016 at 8:30pm |
You could disconnect the rod to the carburetor and manually throttle up on the carburetor linkage itself to see if that makes a difference. Edited by Eric B - 15 Dec 2016 at 8:32pm |
cpg
Posted: 16 Dec 2016 at 8:32am |
Could also check to see if your mag bolts came loose and the magneto rotated. If the timing adjustment you can do by rotating the mag gets off and retards the timing it will seem like its lugging or loaded at full throttle even when its not.
