looking for a picture, fuel line, 35 wc
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: looking for a picture, fuel line, 35 wc
    Posted: 10 Oct 2011 at 6:23am
what is the proper fuel line routing on a duel fuel wc? I found the correct carb but need to know what fitting is missing on the front of the bowl to connect the lines too. thanks, Jesse
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 5:53am
still looking...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 7:24am
Jesse,
 I  believe there was just a tee on the front of the Zenith carb. The fuel line went back to the block and to the tank and the gas line went up to the starter tank. I'll look through some pictures to see if I can find something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:18am
I think I found a picture but the fuel line blends in with the block so well you can't see it. I think the fitting points towards the block and them takes a ninety back towards the tank. does the starter tank get a sediment bowl or just a line with a valve?
Also, who makes the starter tanks for a wc? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:25am
Have you seen this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:29am
Some of the early WC's had the starter tank on the right rear of the hood because that's where it was for the Waukesha engines and they evidently had hoods left over. The fuel lines met at the sediment bowl. I have never seen a sediment bowl on a starter tank but what is left of mine from the 35 has a shut off valve on it. Hope this helps some, I know it doesn't answer all your questions.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 8:48am
Doc Smith has the starter tanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2011 at 9:51am
thanks everyone. that picture looks about how I invisioned it.
