Live Hydrolics for a C
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:44am
Does anyone know how common these pumps are? The one on ebay is an International I think, will that fit on an allis?.......I'm guessing these are in high demand and very few of them made beings this one has almost 30 bids and is near $300 and still has time. I can't say i have ever seen one of these on an allis b or c but I am young and haven't seen everything. Anyone know if allis made these specificly and what models were they found on? Which models are compatible with the b/c?
Thanks Aj.
Can't fix stupid
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:59am
they were not that common. you will need one of of a Farmall. it will bolt right on in place of your mag then the mag bolt to it. they usually go for better than $300 dollars. look for one on a H farmall they were most common thier. you'll need to paint it orange yourself since Allis didn't put them on thier tractors.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:01am
AJ, the pump that works on an IH mag/dist drive will also work on an A-C. So if this one does not get too spendy for you, it's what you're looking for. KipClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:10am
I have seen some pumps for M's that have a gear drive on the front. I wonder how hard it would be to put the slotted mag drive on it and rework the front flange? The gear drive ones seem to sell for much less than the "slot" drive.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:15am
I have an alternator on my c (12v). Will i have to put the mag back one to run one of these?(meaning will i have to go back to 6v)
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:18am
The voltage and alternator have nothing to do with the hydraulic pump. If you have a distributor conversion on it, remove that, bolt the pump on and add you distributor to the back side of the pump. It's that simple.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:37am
Oh ok. I was thinking of the wrong side.
Can't fix stupid
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 8:06am
this is the pump I was talking about, I didnt know they were that pricey I may be persuaded to sell a few it they usually end up north of 300, Dustin
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 2:35pm
I would be content just running one off the side with a pully style set up if I can figure out what pump to get that would work.
Can't fix stupid
jccleav View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jccleav Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 6:40pm
Might look at different pumps for truck plows. The one in the picture kind of looks like one.
The joy is in the journey.
AC "B" and "WD" and "C"
