Later d17 saved from fence row
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 8:57pm
Not logically. All the other bearings look fine. An oil pump failure (there is none) would have ALL bearings damaged, not one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 9:11pm
It doesn't float on top of the oil. It's submerged. Been too long....I think it has an air pocket to keep it raised but it can sink if oil is low or steep hill etc... Either way it's always in the oil so that's not what ruined your bearing.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2025 at 10:35pm
That was what I was thinking but I wanted to make sure.
I will see if I can get it to drain and get it patched up. Probably with have to have it soldered (looks like a visit to the local blacksmith).
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 9:27am
55Allis, how is this fence row D17 patient? Did you locate some good used sleeves/pistons/rings/etc? Or did you go with a new rebuild kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 10:36pm
I’m planning on a complete new rebuild, figured by the time I’m done anyway it won’t cost much more.
The crank is the problem right now, it’s possibly gone too far to have it ground but the guy doing it could possibly get it built up again.
Currently waiting for a phone call from him next week (possibly and hopefully) for a definite answer.
I did get the head fully rebuilt (new valves, guides, and freshened up seats).
Also got the rims for the WD primed and painted so I can put the 16.9s on the D17, at least then I can say it’s on the start to go together..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2025 at 11:56pm
There is zero reason for him to "build up" a crank journal when there are hundreds of used cranks laying around in salvage yards. Bearings of minus .040" should be available for that crank.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2025 at 6:05am
Things like this happen when you have a mechanic that really isn't familiar with Allis Chalmers engines. Unnecessary expensive repairs get done without anyone realizing there is a lot less expensive fix.
A friend of mine has a construction business. His screening plant had an AC 125 (B, C, CA) engine on it. It started putting coolant in the oil. His mechanic, who is a very good heavy equipment mechanic, told him to get another head because the head was cracked. He gave me the old head. I took the core plugs out of it and they were rusted out (not unusual). There was nothing else wrong with the head.
Sometimes paying a mechanic that is familiar with the brand you are working on is worth the extra cost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 1:26pm
Not going to build up, just confirmed that the rod bearings are std and the crank was turned .020 under… Bet that really hammered/knocked when it did run!!
Guy can get me a .020/.020 under crank for $700. Is there any known cheaper options?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 3:37pm
Has the crank been newly machined to .020/.020 ? If it has, the price is in the ballpark
Make sure it is a crankshaft for a G-226 and not a W-226. When I look at replacement crankshafts, some say their crankshaft fits a WD45, D-17, 170 and 175. The G-226 were in the D-17, 170 and 175, but not in the WD45 (which was a W-226). They use different size bearings.
Edited by WF owner - 29 Dec 2025 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2025 at 9:02pm
Thanks for the warning!!
Yes pretty sure it was freshly done.
Sure don’t take long to fill it with green paper …
I was really hoping this one would be saveable but we win some and lose some.
I had a slight hope of finding a junk gleaner around here but I guess the scrap price is too good for that.
I have been going off the casting number (229022) on the crank so hopefully I get the right one.
The spun rod is bad too so I’m wondering if it’s the same as a wd/wd45?
I think I have some of those on hand…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2026 at 6:19pm
Does anyone know of a place to get the clutch disc relined?
The clutch it’s self isn’t too bad, just the pads getting worn down.
I’d rather fix it now before it wears into the rivets.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:37am
Doo a google search for clutch repair or reline. You should find some locally. There are a few near me. Sounth Bend Clutch and Fort Wayne clutch.
If you're doing the clutch you'll need to have the flywheel ground and stepped and also have the pressure plate rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 45 minutes ago at 9:24pm
Clutch measures at 5/16” thick, measuring both pads and the disk its self.
Not sure what the specs are supposed to be..
