Later d17 saved from fence row |
Page <123 |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1106 |
Posted: 09 Oct 2025 at 11:14pm |
I got on A and I parts and search that number
(SK156) and they have an overhaul kit for $918 or $131 for the sleeve, piston, and rings per cylinder. And it says it’s a high compression kit and 4.125” overbore. |
55allis
Posted: 10 Oct 2025 at 2:24pm |
Would anyone know of a ring kit for the sp-48 m and w piston?
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 10 Oct 2025 at 3:40pm |
They are available from some of the aftermarket companies.
If I remember correctly, I got a set from Perfect Circle several years ago. You need to measure the size of the rings. All M&W pistons (for the 201/226) are 4.125" (oversize).
evan austin
Joined: 01 Jul 2021 Location: Gaston Indiana Points: 25 |
Posted: 11 Oct 2025 at 7:48pm |
Steiner lists a piston and sleeve kit P/N ACS3056, 4 1/8" bore, they claim 7.25:1 compression, for $439.99 plus shipping. This is the first time that I have seen the compression ratio listed on one of their kits, maybe it was always there and I didn't notice it before...
55allis
Posted: 12 Oct 2025 at 4:11pm |
Think I’m going good used on the two sleeves due to it being decently low houred and the two good sleeves are very good.
Will put rings and O rings on all the sleeves to prevent problems. Think I will rebuild the head because of a lot of pits in the valves. |
55allis
Posted: 14 Oct 2025 at 12:02pm |
Got the oil pan off today and figured out why it was parked, it had spun a rod bearing…
scott
Joined: 12 Sep 2009 Location: michigan Points: 2754 |
Posted: 15 Oct 2025 at 9:30am |
Is the spun rod bearing on one of the good cylinders?
55allis
Posted: 15 Oct 2025 at 9:40am |
Yes, it was number 4.
1 and 4 has good sleeves but 2 and 3 sleeves are junk. Got all the pistons and sleeves out and the pistons look all good. Even the rings don’t look too bad. |
55allis
Posted: 16 Oct 2025 at 6:11pm |
Found Abilene machine has the overhaul kit for $500 and that comes with everything including shipping.
Only thing is that it’s the original 7.25:1 compression ratio. But it is 4.125 overbore. Also found a guy who might be able to fix my crank shaft quite a bit cheaper. Question: how would I test the oil pump before I put it together? I want to be sure that it has good oil pressure before I put it together to be safe. |
WF owner
Posted: 16 Oct 2025 at 8:33pm |
The doctor can correct me, but I believe only the (gas) 175 had the 8.25/1 compression ratio pistons (maybe some propane engines, too) and they are very hard (almost impossible) to find.
55allis
Posted: 16 Oct 2025 at 9:34pm |
Here’s a link to an A and I high compression kit..
https://www.allpartsstore.com/ItemDetl.htm?ResultsList=251016376624998&CategorySeq=&SelcBrand=&SelcMachn=&SelcModel=&SelcSectn=&SelcSubsc=&SearchDesc=1&TextSearch=ALLIS%20CHALMERS%20D17%20OVERHAUL%20KIT&ItemNumber=IK405 It’s $918 bucks but according to Doc it’s 10:1 compression. I wasn’t wanting to spend that much on it though. Would be curious if anyone on here has done that kit and dynoed it? |
Posted: 16 Oct 2025 at 10:58pm |
175 gas engine is 4 inch bore @ 8.25 to 1 compression. D-17 LPgas is also 8.25 to 1 with 4 inch bore.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3946 |
Posted: 17 Oct 2025 at 8:41am |
no cumbustion chamber with flat tops
55allis
Posted: 17 Oct 2025 at 9:03am |
Found a 8.25:1 kit but I’m NOT going to give $2400.
So I guess it’s going to go to stock. https://www.jensales.com/products/ep-915144-allis-buda-out-of-frame-overhaul-kit-allis-chalmers-g226.html |
wjohn
Posted: 17 Oct 2025 at 8:06pm |
I think I'd go with the lower CR kit at that price too!
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3054 |
Posted: 18 Oct 2025 at 7:03am |
Dumb question probably, but what is the reason for overbore? Why can't you just replace the liners and put new rings on the pistons? Thanks
WF owner
Posted: 18 Oct 2025 at 9:09am |
You can just replace rings. Sleeves should be honed before doing that.
M&W made pistons that were supposed to add power. The were introduced more for the WD45 that had the lower compression ratio. In addition to higher compression than stock, going from 4" bore to 4.125" added 14 more cubic inches to the engine. I suspect that other manufacturers followed M&W for more cubic inches. Other than through AC (AGCO now), I don't remember any aftermarket rebuild kit that was not the 4.125". Sleeves are usually replaced when rebuilding for a number of reasons. These engines usually have lots of hours of run time, when they are rebuilt. Like engines that have dry (pressed in) sleeves or have no sleeves, there is usually some damage and/or wear to the bore. Sleeveless engines have to be bored by a machinist to get a perfect bore. Wet sleeves (like most AC or Buda engines) are relatively easy to replace, so rebuilding is easier (and usually less expensive) than a dry sleeved or an engine without sleeves. In addition, wet sleeves have O rings on the outside to seal them, and the O rings deteriorate over time, so the sleeves have to be removed to replace the O rings. The wet sleeves also corrode over time and it's not unusual to have an old engine that develops pin holes in a sleeve. New sleeves on rebuilding usually eliminates the possibility of leaks.
55allis
Posted: 18 Oct 2025 at 11:05am |
Would it be safe to sandblast the block?
Was thinking about the different panels not matching so eventually I will paint the rest of the tractor. If I could go ahead and sandblast, prime , and paint the block while it’s all apart it would be one less thing to pull apart later. Plus a brand new engine needs brand new paint. |
WF owner
Posted: 18 Oct 2025 at 12:40pm |
Personally, I would never sandblast an engine, especially one that is tore down. I doubt you could ever get all the sand out it.
I would rather pay someone to "hot tank" it. It will also do a better job cleaning the inside of the engine block.
55allis
Posted: 19 Oct 2025 at 10:34pm |
Would hot water power washing be a crime?
I’m just going through and checking cheap, safe options. Got the crank off completely and the main bearings look good. Found this number on the back of the rod bearings. [IMG]Edit: doubled the pictures. Edited by 55allis - 19 Oct 2025 at 10:36pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8671 |
Posted: 19 Oct 2025 at 11:37pm |
Federal Mogule brg and probably their part #. Heard of using easy off oven cleaner where grimy.
ACinSC
Posted: 20 Oct 2025 at 5:41am |
Thanks for the explanation Curt, and good luck Gavin.
WF owner
Posted: 20 Oct 2025 at 6:45am |
I use a regular pressure washer and elbow grease. Lots of spraying (solvent), scraping, brushing, then hitting it with the pressure washer. My pressure washer is 3000 psi and I use a turbo nozzle (stay away from wires and small lines).
I would use a hot water pressure washer in a minute, if I had one. I think the SB on your bearing is probably standard bore or standard bearing.
Edited by WF owner - 20 Oct 2025 at 6:47am |
55allis
Posted: 21 Oct 2025 at 10:02am |
Thanks Curt!!
My Dads hot water power washer seems to take anything off, including paint. I have used it before to clean gear cases with old grease and it removed all of it till clean. Is there a way to test the oil pump while it’s apart? Maybe rebuild the pump too? |
Posted: 22 Oct 2025 at 8:24am |
There is no such thing as a rebuild kit for the oil pump. There are no new parts available that I know of. A good used pump is all you have to work with. I always disassemble the oil pump and inspect the main wear areas. Having a running engine before you tear one down gives you a chance to know what the oil pressure was like. Drive out the roll pin on the top drive gear that mates with the camshaft. Remove the six screws on the bottom and carefully remove the end plate to avoid tearing the gasket (which you don't have). Loosening the screws first and tapping on the plates sides may help loosen up the gasket fit. Remove the idler gear and inspect. Drive downward on the long shaft to free it from the camshaft drive gear. Inspect the bottom gear and especially inspect the long driveshaft for serious wear near the top. If it's worn, it will be noticeable. Remove the pressure regulator spool, spring guide spacer and spring and make sure everything is free to slide. Clean it up and reassemble if the parts all look decent. Pour some oil down the oil tube. Use a rubber tipped blow gun and gently blow thru this tube to 'motor" the pump. DON"T overspeed it. Remove the suction screen baffle (carefully unbend tabs), clean the screen really well and reassemble. Two new bolts and washers to hold the oil pump in place to the block.
55allis
Posted: 22 Oct 2025 at 2:36pm |
Thanks Doc,
Never tore into one of those this far. Figured I’d better check everything being it spun that rod bearing. Been busy with harvest work so haven’t had time to work on the tractor much. I have been calling around for local people with possible parts, so far I possibly have found a hood side and a source for a crank if this one is shot (still haven’t got it into the machining shop). Only time I have is while I’m waiting on a dump. I did get the crank out and the head is almost ready for the rebuild. This thing should run awesome!! Really hoping everything behind the engine works as it should.. |
55allis
Posted: 22 Oct 2025 at 9:35pm |
The main bearings have been turned once I think.
![]() But they don’t look bad.. |
55allis
Posted: 1 hour 30 minutes ago at 6:02pm |
Got a few hours to work on it again so I pulled the oil pump apart.
The shaft looks almost perfect other than a few scuffs, everything else looks fine to me. Is the suction screen supposed to float in the oil pan? It seems to leak oil out of a crack in it. The screen cover had lots of metal pieces in it but I was figuring that since it spun that bearing. |
Page <123 |
