Later d17 saved from fence row
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 48 minutes ago at 7:02am
You absolutely want 8 to 1 compression for the best power and best fuel economy. When you get a 6.5 to 1 kit (which most of them are)  there is less HP and they use more gas.     There is a reason there aren't drain plugs on the final drives. It is because rocks can roll in between the rim and the final drive pan and over time break off the drain plug that shouldn't be there. One quart of oil disappears quickly and then a perfectly good final drive is now toast. You will change the oil one time. It will be the last time. No drain plug needed.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 37 minutes ago at 12:13pm
Does this look like the right one for the money? https://www.agkits.com/Allis-Chalmers-226-Engine-Rebuild-Kit.aspx
It says they have free shipping on this kit.
I was going to go with the major kit to get all the gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 42 minutes ago at 1:08pm
I don't see a C/R listed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 20 minutes ago at 1:30pm
I emailed them on that but they are closed today, so I probably won’t hear from them until Monday.
