K2 Gleaner A/C problem
Message Reverse Sort Order
scott in tenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Topic: K2 Gleaner A/C problem
    Posted: 21 Sep 2016 at 6:26am
Thanks for the reply! I will do some more checking first and let you all know what I find to be the problem. Thanks again. Scott
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:51pm
Got good air flow through the condenser?
If not that will drive your system pressure up to the trip out or belt slipping point real easy.
A plugged expansion valve or valve screen may do it but usually unless you have the system over filled there is not enough refrigerant in the low side to push the high side up that far.   You will simply start to pull a vacuum on the low side which takes the load off the compressor and the system just stops cooling at all.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:43pm
WHAT ARE THE PRESSURES, Probably should be about 80-90 static - 225 high and 15 low. If  the low goes vacuum and the high hits the hp relief pressure shut off valve - the expansion valve is stuck shut.   IF the low is 30-40 and the high is 300 plus the system is over charged.  High head pressure is also caused by a clogged condenser core or fan motors not working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott in tenn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 9:21pm
The compressor on my K2 is building the head pressure so high it is locking up and slipping the clutch. Let it set awhile and equalize and it will turn free. Everything was replace new in the system 3 years ago. I am thinking that it has something to do with the expansion valve but would appreciate some other advice. Thanks in advance.     Scott
