Iso single action high pressure low volume cylinde
Trauschg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trauschg Quote  Post ReplyReply Direct Link To This Post Topic: Iso single action high pressure low volume cylinde
    Posted: 10 May 2020 at 12:07pm
Iso single action high pressure low volume cylinder to run wheel disk behind wd45 thanks for the help in advance
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 5:15pm
Just put any cylinder that will fit on it. All the talk about a high pressure cylinder is 100% "BS". Have done it for years with no problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trauschg Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 5:25pm
I'll just convert a double action by installing vent thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 6:53pm
especially if you go to hold position after stroking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 7:43pm
Well, in defense of the hydraulic cylinder builders, back in the days of AC high pressure system (3400 to 3700 psi), an "M" Farmall was I believe only 1,000 psi, so he&& yes, there was a difference in them. But, today's modern cylinders are far better than that. If you are a sharp operator, you can tell when the disc is almost to the top and just return the lift/lower lever to hold. It will only spike at high pressure when it hits the top and then a couple seconds later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 7:56pm
re: All the talk about a high pressure cylinder is 100% "BS". Have done it for years with no problems.
kinda like playing Russin Roulette.......
A good 1000PSI cylinder will be tested at 3000# ( typically 3x the rated normal pressure), same as air tanks ( 300# tank, tested at 900# )
plumb a worn 1000# cylinder to a real good 3800PSI pump... cycle it a few times...
it'll blow, eventually, same as Russian Roulette..
a 1500# cylinder would be burst tested at 4500#....maybe....
and just WHERE was the cylinder made ???
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 8:57pm
Your big bolted together cylinders will be slow to lift plus after using for a while. It will stretch the bolts to where it will blow end seals.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 6:45am
I have some used Factory high pressure AC cylinders available. One of them is a 2 way. You can email me directly at: the1orangewizard@gmail.com
Edited by PaulB - 11 May 2020 at 3:04pm
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 7:54am
How do you tell a high pressure cylinder from a low pressure one?
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:04am
you'd hope the cylinder has some kind of MFRs part number on it.....
BTW a couple hydraulic sites say the burst ( test) pressure is 4X !! not the 3X I was lead to believe....
so a 1000# cylinder 'shouldn't ' fail at 4000PSI which is more than most A-C pumps put out...
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:05am
Where are you at in Ohio?  I'll check, I might have one.
Life is simpler when you plow around the stump.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:13am
A "worn" cylinder??? About the only thing I ever saw worn was the seals, ….which BTW would bleed a little pressure! LOL I've got cylinders around the farm that are probably 60 years old. I did have an old cast iron cylinder split LENGTHWISE when the tail wheel of a plow slammed over a rock or something. Didn't know it until the end of the row when the plow wouldn't lift and oil sprayed all over the back of the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:38am
Official A-C high pressure cylinders are never larger than 2 inch in bore diameter. In fact, I think 1 3/4" is the largest I remember.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:49am
Allis hi pressure cyl are "skinny "compared to anything else. I know they made 2 different diameters. I have a couple of each but don't know diameters.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:02pm
Hi pressure screw together lo pressure usually bolt together.       MACK
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 11:07am
i would bet the pump isnt putting out anymore than 2000 anyways unless it has been worked on recently
This page was generated in 0.262 seconds.
