interesting read (oil zinc levels) |
Page <12 |
BenGiBoy ![]() Orange Level ![]() ![]() Joined: 11 Nov 2015 Location: Ashville, NY Points: 705 |
x2, I have read somewhere that one cold start (cold cold, like cold enough to need an oil pan heater) in a car = 500 miles of wear (I forget now if it was 500 or 5000, but I think it was 500, 5000 seems like it is a bit high...) |
'39 Model B
Tractors are cheaper than girls, remember that! |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
Valvoline VR-1 Racing oil contains increased zinc.
sason ![]() Bronze Level ![]() Joined: 18 May 2014 Location: Moran Ks Points: 178 |
we ran this in our pulling tractors.
https://lucasoil.com/products/engine-oil-additives/engine-break-in-oil-additive-tb-zinc-plus |
180 with a turbo and 460 loader.
kenbob ![]() Silver Level ![]() ![]() Joined: 24 Sep 2017 Location: Smithville Mo Points: 162 |
I think your 5000 figure is right. That article I read the wear was more than 90% I think it was 97 or 99% but I said 90% to be conservative. Seems like if you had a good engine and never shut it off except to change the oil, it would run forever or close to it.
DakotaSteve ![]() Orange Level ![]() Joined: 26 Apr 2017 Location: SD Points: 717 |
I think the most important part to this is as collectors our tractors sit more than they run....through the changing temperatures of the season's and just time itself the oil starts to run off of the steel parts inside, the next time we start the engine it runs without sufficient lubrication on the surfaces for a period of time due to the oil being cold and having a thicker viscosity or maybe due to the older lubricating system and that it's just not there yet. The cam lobes and followers can start to develop small amounts of corrosion that runs into Spalling on the followers and surface delamination on the tips of the cam lobes....this is where the zink kicks in to protect this all. I agree with the above responses if we wouldn't be using advanced exhaust systems with O2 sensors and electronics we would still be using oils that are more zink fortified.
Another topic is starting....people say well I just start it for a few minutes a couple times a year so I know I'm good.....Well, this may be causing more harm than good. As the engine starts to warm up condensation is made due to temperature differentials, this could be worse on a cooler day for example....unless you get the engine to full operating temp to completely burn off any condensation that has been introduced into the crankcase u may be shutting the engine down with small amounts of moisture inside that will induce rust more than if you'd of left it alone until the next time you were going to run it for a longer period of time. |
Here are a couple pics I took of cam follower Spalling. This engine sat without running more than it ran but was used every year.
ac45dave ![]() Orange Level Access ![]() ![]() Joined: 23 May 2015 Location: SE(IN) Points: 1346 |
x3 steve on your last two posts!! this was the point of my two threads on this subject.just trying to save us all some grief down the road.
Edited by ac45dave - 12 Feb 2018 at 9:28am |
AC45Dave Knowledge means power....just like the old Allis manuals....ha!
Throw it out there and people can sort through what they feel could help them. |
The more I think about it the more I think it is, because I remember it being kinda shocking how many miles worth of wear it was.... DakotaSteve.... I agree completely on the condensation issue, the amount on the outside of my engine I assume is sorta close to the inside, and that is a LOT of water getting into my oil. ![]() - Ben |
'39 Model B
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Which is why thickW-Thicker is not the best oil to use. Use an oil that flows freely in the coldest weather, yet maintains adequate film strength when hot. If your tractor manufacturer recommended SAE 10 for winter use in your area, don't use 15W-40. |
I agree on viscosity....another benefit of the synthetics....they have a much better flow rate at a given temp than most petroleum based oils, therefore they are going to get to where they need to be faster.
For example...I use a 0W-40 weight in my Honda Foreman. I use it for ice fishing in the winter as well....when it's -20 on the ice and I start up..it's flowing like a 0 weight, when it's 90 in the summer it's flowing like a 40 weight. You wouldn't do that with petroleum based oils. |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3941 |
seen a post about bon ami that is for seating rings not for ruining a flat tappat cam
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 710 |
I've used Rotella 15W40 in both my old motorcycle and old tractors. So far, so good. these are opposite ends of the RPM scale- My '70s Yamaha redlined at over 9,000 rpm and the tractors are under 2,000. Has worked fine in both. I switch to 10W30 in the winter (for the tractor, motorcycle hibernates), but it's still Rotella. I see no reason to buy anything more exotic or expensive.
Edited by HoughMade - 12 Feb 2018 at 11:52am |
1951 B
Ford in fact is still using flat tappets in 4 and some 6 cylinder engines. Just did a water pump on a 3.5L Explorer. Driven by the timing chain so the front cover has to come off along with the cam covers. Cadillac North Star is also flat tappet.
The ZDDP and zinc may have been reduced in modern oil, but the friction modifier package has been changed too. Take another look Steve. That left pic is rust pits without question, the right one the lifter stopped spinning.
Brian, yes I agree. I personally feel that the zink in the oil helps prevent things like "Rust".
Engines that sit more than they are ran can use anything that's in their favor to help their longevity. Oils have been discussed and discussed for many years....I'm sure that won't change. I think as long as the info is out there folks can pic and choose what they believe in and what suits them. ![]() |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34369 |
Now the question, what is Mogas? Just a little better quality of old car gas or without alcohol in it? Will it store better? Thinking of putting something more stable into my infrequently started gas powered toys. Thanks |
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
JC you are using sideways math there.
JC you are right I am wrong, I looked at the numbers sideways. Sorry guy.
Page <12 |
