Installing 7000 engine in HD6G
south ks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote south ks Quote  Post ReplyReply Direct Link To This Post Topic: Installing 7000 engine in HD6G
    Posted: 10 Jan 2016 at 5:08pm
Hi I'm new to this sight. I have a 1957 HD6G, I might have located a 7000 military engine for this, I am just wondering if the flywheel and clutch housing from the old engine will fit on the 7000 engine? Is there anything else I will have to install on the new engine from the old engine? thanks
Danny NM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danny NM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2016 at 8:27pm
Hi South ks a few years ago we put a 7000 engine in a 1956 HD6. it was a generator engine and we used the original 344 buda flywheel and bellhousing. had some clearance problems with the starter,oil filter,fan blade. also had to have the injector pump respringed to allow for a range of throttle and not just wideopen as the generator needed. hope this helps this is a very good site welcome to it Danny
