Identify This Tractor
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Identify This Tractor
    Posted: 17 Nov 2020 at 3:02pm
I am not knowledgeable enough about A-C's to know what model this is
https://spokane.craigslist.org/grd/d/chewelah-allis-chalmers-tractor-with/7213481656.html
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 3:22pm
It's an early D-17 that needs some TLC for sure but if it runs good, price is not out of line, rear tires don't look too bad.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 3:35pm
Can you tell if it is a gas or diesel engine?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 4:11pm
Gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 4:24pm
Thanks for the replies.
I (my Wife actually) inherited two tractors, a WD and a WD-45, both with stuck engines. I drove the WD quite a bit some years ago, but when I got my own compact tractor I never needed to borrow it anymore, so it sat and got stuck. I tried all of the various snake oil remedies and hung 100# of weight on the crank handle all last summer, but to no avail.
Either tractor will require $2000+ at minimum to overhaul, and that is with me doing the work.
Just weighing my options as a running tractor for $2000 may be a better plan.
Thanks again
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 4:36pm
Believe it is a D15 or D14. The dish in the rear rims is wrong for a 17. Also one of the pictures from the rear shows a curve/ bent gear shift.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 4:48pm
Not a D17, for sure. I’m leaning towards a D14, if the monocolor paint is original.
Edited by TramwayGuy - 17 Nov 2020 at 4:49pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 5:06pm
 Look at trans and axle housings .14 or 15  My best guess is D 14 with narrow draw bar Vail
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 5:43pm
1959 + D-14.  JMHO, at this point.  Looks like a 3 bar grille behind that bumper...Wink
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 6:00pm
I say D-14, no thumb Guard on Power Director Lever, dead giveaway not D-15.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 6:24pm
dished wheel centers, bent shifter, D 14
phil
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 7:08pm
looks like a D14 with a Paulson loader, I have the same tractor here in the yard
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2020 at 9:01pm
It is a D14 and not a 3pt hitch. Wheels looks like it spent a life time in a cattle lot.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 2:23am
yeah....where is the 3 pt hitch?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 6:26am
Early D-14  '57-early 59 pre black bar grill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 9:29am
Wow, you guys are good! :-)
So is a D-14 sorta like an enhanced CA? I own a C, and am familiar with the CA, but is the D-14 as good as a tired WD?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 10:28am
Well, when the D14 came out dad bought the first one with 3 bottom plow and cultivator,
traded in a C with an Oliver 2 bottom plow and a 2 row Cultivator, a rope controlled tumblebug, some old harness and other things I've forgotten as I've slept since.
The WD will outwork the D14, but if you add a light spring to throttle rod and adjust the WD will keep up, ground speed wise, when plowing the same field, and the WD will pull better.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 10:48am
The D10/D12 are enhanced CAs.  The D14/D15 are more in the category of a WD (but not as powerful as a WD45).
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2020 at 10:49am
Well, there are 3 attachment points on a Snap Coupler hitch.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2020 at 6:19am
This one has a Du-al loader.
Edited by Nathan (SD) - 19 Nov 2020 at 6:20am
This page was generated in 0.088 seconds.
