Identify This Guage? |
Gerald J.
Topic: Identify This Guage?Posted: 01 Jan 2011 at 11:58pm |
Probably pressure or vacuum at the steam exhaust of a steam engine or turbine into a steam condenser. A steam condenser tends to pull a vacuum on the engine or turbine when its working right condensing steam and that's more pressure drop across the engine or turbine to extract more hp from that machine.
You want to see the power of condensing steam, take a metal can with screw on cap, like a solvent can, put in about 1/8th can of water, put it on a stove or hot plate and bring that water to a boil. Take it off the heat, screw the cap on tight and let it cool. You'll need oven mittens to do that safely. Let it cool. The condensation will pull a vacuum to the point the can will be crushed down to the volume of the water it started with. Gerald J. |
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 01 Jan 2011 at 9:44pm |
Likely messuring water column pressure. Very small increments compared to PSI.
J D (Ont)
Posted: 01 Jan 2011 at 9:39pm |
I think the gauge units must be "Hg, (inches Mercury)
It would be hard to get 30 psi vacuum on earth where atmosphere is about 14.5 psi
What I cant figure out is how you would get negetive pressure on exhaust ?
Breeze
Posted: 01 Jan 2011 at 8:31pm |
it looks to be in good condition other than the 6 pounds off factor.
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 01 Jan 2011 at 8:30pm |
Im betting it was on something Steam.....
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
morton(pa)
Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
Posted: 01 Jan 2011 at 8:29pm |
It measures the vacuum and pressure of something? Maybe a turbine of some sort? Allis did make lots of them...
CTuckerNWIL
Posted: 01 Jan 2011 at 8:21pm |
Why it's an Exhaust gauge?? Shows vacuum and pressure.And it's about 6 lbs off. LOL
Edited by CTuckerNWIL - 01 Jan 2011 at 8:22pm |
CTuckerNWIL
Posted: 01 Jan 2011 at 8:20pm |
morton(pa)
Posted: 01 Jan 2011 at 8:11pm |
Just a shot in the dark, would definitely be able to tell with a larger picture, but it appears to be a Steam Pressure Gauge from a Factory boiler or piece of machinery.
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Posted: 01 Jan 2011 at 8:03pm |
that is the picture. how did you do that?
CTuckerNWIL
Posted: 01 Jan 2011 at 7:52pm |
It needs to be a better picture. I got to your photobucket album but the picture isn't good enough to blow up. It could be a steam pressure gauge?? If the picture was better before uploading to Photobucket, send it to my email and I will post it. Charlie 1954wd45@gmail.com
Edited by CTuckerNWIL - 01 Jan 2011 at 7:52pm |
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 01 Jan 2011 at 7:49pm |
This one ? :
http://www.rumelyallis.com |
Dave (NE)
Posted: 01 Jan 2011 at 7:39pm |
When I try to get the picture from photobucket, I keep getting a message about global settings. Anyone know what the deal is?
Dave (NE)
Posted: 01 Jan 2011 at 7:36pm |
Well I can't seem to bring the picture up. I'll keep trying.
Dave (NE)
Posted: 01 Jan 2011 at 7:35pm |
