ID of these rear wheel weights please
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Topic: ID of these rear wheel weights please
    Posted: 16 May 2019 at 10:14am
What do these fit? Thanks.
https://wausau.craigslist.org/grd/d/curtiss-allis-chalmers-wheel-weights/6885496980.html
Edited by JaredC(WI) - 16 May 2019 at 10:15am
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 10:36am
They look like the weights we had on our WD-45, you will need the nuts, bolts and washers.
Dave
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 10:59am
WD-WD45-D17 + more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 12:39pm
Cool. Would they fit a ca or be too big?
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 1:30pm
Sorry, too big for a CA.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2019 at 10:03pm
B's used a similar one only difference was an additional notch. Look in the information section, they have pictures and models.
FRONT OF THIS WEB SITE --FARM EQUIPMENT -knowledge BASED
Edited by HaroldOmaha - 16 May 2019 at 10:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 4:45am
Need a pic of the part # in the casting.  Could be D-14-17, or WD-WD45...  if you want them for something, measure between opposite mounting holes, to see if they will fit what you have...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:23pm
Easiest way is to look here:
http://www.brianahart.net/weights.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 12:37pm
Thanks guys! Gal dang, hidden in plain sight! Through I'd read everything on that page. Ha ha, there's a reason I have glasses :)
Thanks again.
