I screwed up big time……………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: I screwed up big time……………
    Posted: 8 hours 36 minutes ago at 9:38pm
1991 F-350
Was messing around in the shop today, thought I would look at the Craftsman battery charger my Son has, that will not work right on his BMW. So I figured I would hook it to the batteries on the 350 and investigate. Turn on the headlights, to give the charger something to do, after maybe 3 or 4 minutes I noticed the clearance lights on the truck went dark. Headlights stayed on.
Opened the fuse box, fuse In position #4 blown, replaced fuse(15 amp) pulled light switch out, pop goes the fuse. All other lights work, brake, signal, hazard.
Clearance lights, and dash lights(they are tied together) will blow the fuse.
Any idea on where to start before prodding around on 30yr old wire harness?
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 17 minutes ago at 11:57pm
I think I would get an auto reset circuit breaker to put in place of the fuse (only for testing, you will want to go back to a fuse once it is fixed) and turn the lights on. Then observe to see if there are any lights that don't come on for the brief moment the circuit breaker comes back on. If it is in the dash lights turning them all the way down should cause the breaker to stay on a little longer. The other potential trouble spot can be a trailer plug if it has one, last thing you think of because it doesn't light up. Hope this helps get you looking in the right direction.
Edit: I should also point out that using an auto reset circuit breaker will heat the wires going to where the short circuit is, and leaving it on too long may lead to a fire.
Ted
Edited by TedN - 6 hours 7 minutes ago at 12:07am
This page was generated in 0.039 seconds.
