Hydraulic Pump Allis Chalmers C
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Pump Allis Chalmers C
    Posted: 7 hours 26 minutes ago at 10:49am
Hi
On the hydraulic pump of the model C ; there are 4 balls
- 2 balls for intake valve item 27 , ref number 70915904 , 5/16" , is it correct?
- Another one is the discharge valve ball. But no Item ? and of course no piece number.
- And the last, Releif Valve item N° 7 reference 70915906 . This should be smaller only 3/16" does this size correct ( the others are 5/16")
What is the reference of this discharge ball?  Or the diameter size
Or i am a little confuse , may item 2 with the Insert assy 70213522, there is a second line with Ball discharge same reference than intake,   but they  put qtty = 2 ? why i see only one?
Edited by John426 - 7 hours 8 minutes ago at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 29 minutes ago at 3:46pm
i think #3 and #21 ( intake and discharge) are the same size... #10 is smaller.. i dont remember the diameter.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 24 minutes ago at 3:51pm
Takes 4 70915904 Balls for intake and discharge 5/16 and 1 70915906  for relief valve 3/16
