Hydraulic Coupler Male
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Coupler Male
    Posted: 11 hours 8 minutes ago at 11:26am
Trying to rig up a guage to check pump pressure on the rear of a D21. Which type do I look for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 6 minutes ago at 4:28pm
I thought one type was called pioneer, don't know what the older couplers were called.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 11 minutes ago at 5:23pm
Balls are usually Pioneer brand. Points used to be Bruning. Your results may vary.
Edited by DrAllis - 5 hours 10 minutes ago at 5:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 12 minutes ago at 6:22pm
So it could be either so better have both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 1 minutes ago at 6:33pm
After 60 years, who knows what's on some of these tractors. It could have John Deere couplers on it for all I know.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 9:03pm
Do you have any hydraulic cylinders that are used on the D21.?  I'd take 1 of those ends off its hose and use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 minutes ago at 10:07pm
look at the end of the MALE piece.. does it have a BALL or a TIT on it... that tells you something...Most are interchangable, but the BALL is old style... Then take a caliper to comfirm " barrel size"  of various  1/2" or 3/4" types..... couple different versions... see below...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 minutes ago at 10:16pm
this is what GOOGLE said....... 1/2 inch PIONEER 4000 series ..ISO 5675 Agricultural
The Allis-Chalmers 180 tractor typically used 1/2-inch body, Pioneer-style agricultural hydraulic couplers (often referred to as ISO 5675 or ball-style connectors).
 +4
  • OEM Part Number: The male coupler tip specifically for the 180 is often identified with the Allis-Chalmers part number 247336V or 247336.
  • Compatibility: This coupler style is standard for many Allis-Chalmers models from that era, including the 170, 175, 180, 185, 190, and 7000 series.
Edited by steve(ill) - 12 minutes ago at 10:22pm
This page was generated in 0.273 seconds.
