How much fluid?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: How much fluid?
    Posted: 04 Sep 2019 at 7:51pm
How much calcium chloride fluid would there be in a 24.5 x 32 rear tire on a D21?  The manual says 1600 lbs of weight, but I need to know how many barrels I will need to drain both tires.  I know both tires are near full, but I don't have a clue in terms of the number of gallons.  The new tires will be dry, but the cost of them has my eyes wet!
Thanks in advance!
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 7:59pm
You’re tire man can tell you how much is in your tire by the charts they have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 8:00pm
CaCL weights 12 pounds per gallon ......... so 1600 / 12 = 133 gallons.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 8:09pm
Found charts that say 140 to 170 gallons of water per tire, depending on the chart. Higher percentage of calcium the less water. Search now much ballast in 24.5 x 32 tire and you will find several options of charts.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2019 at 8:24pm
Weight varies by specific gravity
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 5:07am
Just as a reference, when I drained a pair of 18.4 x 28 tires, it took three 55 gallon drums for two tires.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 12:07pm
Use plastic barrels. Metal ones can dissapear in Les than a year.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 6:38pm
