How big is TOO big when it comes to discs ??
hootsandgiggles View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hootsandgiggles Quote  Post ReplyReply Direct Link To This Post Topic: How big is TOO big when it comes to discs ??
    Posted: 10 Apr 2014 at 4:14pm
I was just wondering how you determine how big of a set of discs you can run behind a given size tractor ??  A friend told me I was most likely nuts (and he's likely right, on all other counts) ...  to try to pull a 12 ft. transport disc behind my D-17 Series IV ...  although I'm pretty certain I saw one of those old A-C videos where they were pulling a 16 ft. behind a WD-45 ??  Any thoughts ??  As always, your help is appreciated.
Thanks,
Mike C.
Mike C. - NW PA     **Jeremiah 29:11**
65 D17 Series IV gas wfe
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 4:26pm
We pulled a 212 w/traction booster with our WD45D in 2nd gear for many years. My uncle pulled a 214 with a D17 diesel.
ALLIS EXPRESS!
This year:
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 4:34pm
The disk is too big when the tractor rears are acting like a rototiller but not moving the tractor forward.
I took the wings off to get the disk down to 12 or 14 feet to pull behind my 4020. I learned from an old timer that pulling it at 6 to 8 mph was important for week killing. The high speed flips weeds up in the air and they stay on top and dry and die. Pulling much slower does stir the dirt but grasses seemed be be encouraged by multiple slow disk passes, not killed.
I took an Oliver 12' disk and converted it to a 6' offset disk to pull with my MF-135 and being heavy it did a good job on the dirt.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 4:38pm
Gerald,
It would be neat if you could post a pic of that modified disc and how you did it..
Mike
HD6GTOM View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 5:22pm
Mike I pull a 13'6" Kewanee behind my series 4 diesel with no problems, high side of 3rd, and shift back on the steep hills when turning on the ends.   As a mater of fact, I have a tendency to go too fast and throw ridges. I put all new blades on this a few years ago and I raise the wheels off the ground when I am pulling it.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 7:16pm
Some older discs are 25 to 40 lbs per blade in weight and more modern discs might be 120 lbs or more per blade. Just claiming to pull a certain width of disc is only 1/4 of the story. Weight per blade and diameter of the blades and the angle of the gangs all play a huge part in how much tractor (and tires) it takes to pull it.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 7:35pm
  pulled a 10' wheel ac disk with a spike tooth harrow behind the disc  with my wd   we used duals on our tractors in the fifties  plenty of power left over   my 2 cents
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 7:38pm
Amen. I was flipping through a new landoll vt7430 manual yesterday and they suggest a minimum of ten horsepower per foot. A wd45 would have its hands full pulling that disk without even lowering it.
Cen IA John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cen IA John Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 7:53pm
My WD could only pull the 8' SC disc, the D17D was able to pull a 14' JD RW(not a real heavy disc). 190XT was a 20' IH 480 with ease. 7020,8030 & 8050 was a 25' IH 496 with no problem. As stated the weight of the disc makes all the difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 8:06pm
Dr. Allis is correct.  I had a 14' Kewanee with 20" blades that my 190XT just played with, so I traded it on a Kewanee 18' 1010 hydrofold.  The first time I dropped it in the ground it killed the 190 before I could get the clutch in.  When they sent me the book on the disc, it recommended 136 HP.  I still used the disc, but with spacers in the lift cylinders to limit depth .
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2014 at 8:28pm
Gerald J.
Pulling a disc at 6-8 mph would be disaster !! Going that fast would move a lot of dirt and create ridges. Unless the weeds are huge you would not want to use a disc for weed control. Field cultivators and finishers are a different story you want to get them up and moving to do better. The size of disc greatly depends on how good of a disc you have a newer heavier better disc pulls a lot harder. My grandfather pulled a 12ft Oliver with his D17 my 8030 struggles with my 22ft Sunflower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2014 at 8:10am
No disaster at 6+ mph. Before I added two rows of spring tooth behind the disk I made three passes with the disk and left with a nice smooth seedbed. This was after spring moldboard plowing. Then I did a shallow FC pass and the FC has three rows of spring tooth on the back for that final smoothing.The Shoup shovels I put on the FC didn't kill any weeds until I spent half a day under the FC with a grinder converting a blunt edge to a sharp edge.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hootsandgiggles Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 1:49pm
Well, I bought the discs and brought them home on Saturday !!  The seller apparently did give them a "thorough going through" ...  all bearings and blades appear healthy ...  He told me and showed me where he had done work and replaced parts.  He had some original tools and a full extra set of disc scrapers that came with it.  Got it all for $850.  I am very happy and I can't wait for the fields to dry up around here so I can take them for a proper test drive !!  Thanks to those who chimed in on this thread with their opinions and advice Thumbs Up
Mike C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 3:54pm
Gerald J.
Between plowing and the NASCAR like discing could you have done anymore of a disservice to the field? Unless you are burying sod do you realize how much damage to the soil you are doing with a plow? How did the weeds get so big the field cultivator had issues?
Edited by victoryallis - 14 Apr 2014 at 3:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 4:11pm
Everybody has their opinion, if you don't know the other guys terrain and soil conditions, you have NO IDEA what you are talking about.  Some guys near me haven't "plowed" in 30 years cause they have rolling hills. Other guys plow their "bottom" ground every other year or more. Gumbo bottoms is way different than sandy clay hills.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 5:40pm
Gerald J.
Plowing depends on your soil type too. Around here moldboard plowing has been making somewhat of a comeback. My agronomist says higher yields have been recorded on moldboard plowed ground. Myself I prefer chiseling.
Wink
I am a Russian Bot
Jwmac7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jwmac7060 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 7:05pm
I'm on sandy gravel soils in central Indiana. Over the years we have tried it all. No tilling my ground does not work. We have went back to mold boarding and chiseling. Not only has my yields increased but my chemical bill has decreased since stopping no till.We had so many weeds that had become resistant to chemicals that tillage became the only way to address them. That's what works for us right now
stroketech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 7:40pm
Hey Hoots, I have a Series 4 17 with a 12 foot Allis disc that looks exactly like the one in your picture. I have an 8 foot piece of rail road rail on the back of it and the 17 pulls it like its an ertl toy.
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 8:55pm
   You did really good on the disc at that price , and , it looks
like you bought it from the type of person we would all like to
buy from ( somebody who took pride and care of their equipment ).
Best of luck .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 10:22pm
You would really like it with the snap coupler torsion bar hitch.Ask him if it's still around somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2014 at 10:28pm
D-17 series 4 with 16.9 x 28 duals and snap-coupler Traction booster hitch works really nice with a 13 ft 6 inch wide disc just like that.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2014 at 12:59am
Mind you she's not stock but our WD45 played with our 12' AC wheel transport disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2014 at 8:50pm
It's hard to argue the science in relation to plowing, carbon loss, and organic matter and the effects of lower organic matter on crops. We have had feilds side by side one plowed one chiseled similar soil get a heavy rain the plowed portion is like pudding down to the bottom of the plowed area chiseled area much firmer. Also notice that plowed ground suffers more in droughty weather.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2014 at 1:12am
when ya hook onto it, sink it in the ground, if the tractor wheels sit there and spin, it's to big!
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 3:02am
I am sorry, I have nothing constructive to add to the topic, but the topic sentence makes me thing of these discs:
here is a sign the disc is too big for your allis: 42 inch blades on 20 inch spacing... :O
http://www.biggmfg.com/index.php/equipment/deep-plowing-discs
They also make the world's widest disc, explore the website a little, it is amazing. :)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 8:23am
I know that this one was to big for my WD45. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2014 at 8:28am
It was a SC so I pulled it home behind the WD45 and that was the last time it hooked up to my WD45. lol
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 8:54am
I just bought a 213 Allis transport disc this last summer, it measures 13,6" across. My series one D-17 with loaded 16.9-28s and one set of rear F&H weights pulls it with no problems in second High. I've since disced in corn stalks in sandy ground with it on some decent hills, and disced plowed blue clay at my house with it. I've also pulled a 210 Allis transport disc with My CA. it loves it, of course having a 1000 lbs of wheel weights on the back help a lot.
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 9:07am
A disk with dull blades will pull much easier than a sharp disk. Of course this is at the expense of penetration.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 11:09am
needless to say thats still a nice clean looking disc for 850 dollars.        looks like it will work the crap out of that tractor anyways
This page was generated in 0.108 seconds.
