Help! remove U joint from mower
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Help! remove U joint from mower
    Posted: 02 Dec 2010 at 5:15pm
I am trying to replace the U joint on my 172 AC mower. I can not get that old one out. I have got it off of one side, but cannot get it off of the other. any suggestions? I may have to torch it out. I am having a hard time getting it to move one way or another. And yes, the snap rings have been removed.  Dave
LoggerLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:19pm
I like to have some extra weight for some stuff,if you can have a helper hold a sledge against the other side of the yoke to keep it from dumping your energy back into the gearbox or drive or whatever that can sometimes help.
Otherwise I'd say heating a little with a torch if you have it will probably work.
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:20pm
 Dave, I am not sure on AC machines but some car and truck ujoints have a wax/plastic type seal/pin to help hold them and you have to heat the cap area to melt it. Even though it is a wax/plastic "pin", it is hard enough that you cannot drive the cap out without melting the "pin".
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 5:47pm
Dave load it up and come on down I have done lots of them.
Don
This page was generated in 0.348 seconds.
