Help needed on 7000
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: Help needed on 7000
    Posted: 21 Jan 2017 at 5:04pm
I went and looked at a 7000 maroon belly tractor today and it's got transmission issues. The problem is that the oil will start to turn black and it will start coming out around the gearshift leaver. Does anyone know what the problem may be?
Edited by AllisandGleaner - 21 Jan 2017 at 6:59pm
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 8:09pm
Any idea on hours?
How long does the oil take to start coming out?
Are the oil levels correct? What is the age of the oil?
Any more information you can provide would help...
~Warren
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 8:17pm
7,500 hours and the man would run it until it would do itand I think when it would turn black he would change it and he would use the side sight glasses to check it
Edited by AllisandGleaner - 21 Jan 2017 at 8:18pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 9:05pm
There is a plug forward of reverse idler shaft. This plug has about a 3/4 hole in it. Get that plug out will help that problem in cold weather.      MACK
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 1:30am
Mack ,
What about the breathers on top of the trans?
Maybe they are plugged and need a cleaning?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 7:30am
Well where else could oil be getting in it at the man said it looked like motor oil but it's a dry clutch tractor kind of got me puzzled. The man was cutting hay with it then it started messing up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 12:55pm
The shaft seal on the hydraulic pump could be sucking motor oil into the hydraulic system causing this. Engine oil would be going down if this was happening and hyd oil would be gaining. Power Shift clutches are hydraulically activated.
