Hd6g clutch problems
Jhilton69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g clutch problems
    Posted: 16 Jul 2025 at 10:04pm
Hey yall just got back up from flordia. Put my brother in law on my ol gal and now the clutch won't engage. I figured he knew what he was doing since he runs a crew of asfault guys. I rode with him at first and he got it I thought. After an hour or so he messed her up. When I pulled the floorboard panels up I noticed a rod on the right side that moves with the clutch handle bit it's not connected to anything and I can't find any information on it. Figured I'd see whatbuall think before opening her up and adjusting the clutch on her. Please help.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 7:02am
The right side rod is the plunger shifting lock
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 10:55am
Thank u what does it go too? I haven't found anywhere it hooks up too. Does it affect the clutch engagement?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 12:53pm
THE rod should be connect to a other rod with a boot on and she is going in the front transmission  shifting housing and this rod is loock the transmission in gear when the cluch is angaged and this should affect the cluch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2025 at 8:58pm
I searched around and couldn't find any other rod for it to hook too. I didn't get a chance today to do a pull test on the cluth lever gonna do that tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:08pm
Well done my pull test took a lil over 35 pounds to pull the lever over. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:22pm
The master need 25lbs to 30 lbs maximum and the cluch should angage with a distinct over-center snap (engine stop)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:56pm
Ya i can feel it snap over like it's supposed too. I got tje floorboards out and when pulling the lever back everything with the exception of that rod on the right side looks good
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 44 minutes ago at 11:40am
I am lost as to what is not working.
There is rod that locks the shifter up when the clutch is engaged. Unless that is released it should not come out of gear.  Is that the trouble?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 47 minutes ago at 12:37pm
I can start her in gear to move her around to stop i just shut her down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhilton69 Quote  Post ReplyReply Direct Link To This Post Posted: 48 minutes ago at 10:36pm
It acts like it's not engaging the clutch when the lever is pulled back. But when I checked the pull it was just over 35 pounds. The floorboards are out and watching the levers it looks like it's working. Bit it won't go in gear when running just grinds
