Hd6 wet clutch pump
Primos75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Topic: Hd6 wet clutch pump
    Posted: 18 Apr 2026 at 11:52pm
Hello all, does anyone know of a replacement pump for the wet clutch on my hd6? Mine is toast so I rigged up a diesel lift pump to a switch but I don't think it's building enough pressure to over come the filter and internals plus it loses prime very easy. Im open to suggestions or replacements. Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2026 at 6:12am
Let me have your pump number I maybe have one on racking
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2026 at 9:17am
Unfortunately I don't have the pump any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2026 at 8:14pm
Is there more then one style of pump for a wet clutch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 3:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 3:48pm
Pics for reference
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 7:10pm
I have the small pump  t 27491 = 620201
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 10:56pm
I think that's the one. Does it have the fork or pump drive coupling on it still? That part number for the coupling is 630914. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 6:32am
I should have the pump fork and I try to open the pump for check inside condition
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 9:04am
Thankyou
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 11:37am
I check the inside pump and she loog good but the fine shimm inside is bad and when am turning the shaft left side she oké but right side he turne and stop  and have the fork
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 4:30pm
So it cant be used like it is i guess. What would it need? You think it can be fixed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 5:52pm
Am tinking the pump need the gasket 621363 inside for adjustement but am not a mechanic men
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 4:18pm
Out of curiosity, what would a pump that potentially needs repaired go for? I may have another lead on a not so good one to. Might be able to take two and make one.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 4:20pm
They are a 'barnes' pump.   And afaik are same fuel pump is used on smaller detroit 2 strokes
tits tyres and tracks
they all cost you money
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 8:06pm
There are right, and left rotating fuel pumps on the Detroit engines and they are not interchangable.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 8:27pm
Is there anything different between the pumps on the 344 for pumping oil to the clutch and what the Detroit, im guessing 2-71, would be for pumping fuel? I know it couldn't be as easy as that..lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 9:02pm
It could be that easy. A-C was very good about using off the shelf products if they could to keep costs down. Pumps on the two strokes will work the same whether a 53 series, or 71 series. The only real differences are rotation direction. There are high volume pumps too, but those are mostly for higher performance engines. They are a small basic two gear pump with a sliding shuttle serving as an internal pressure relief system. Though I've not seen one of these in another application, only a spring change would be needed to adjust relief pressure.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 9:10pm
I wonder if anyone's tried this or if it can be done. I've had no luck looking up the part number. Salvage yard near me would pull one of an old machine for $300 but I dont know about that. Seems a little high. My buddy has one on a non running 6g but it would be a bear to get to.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 9:56pm
This is a screenshot of the Barnes fuel pump for the 2-71 Detroit Diesel from the HD5 parts manual:
Edited by Les Kerf - 22 Apr 2026 at 10:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 10:31pm
That is a left hand pump shown in the photo.
Edited by Codger - 23 Apr 2026 at 5:35am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 11:20pm
Very similar to the wet clutch pump i posted. Does anyone know what the psi and gph the pump should have for the clutch? The manual says the filter has a bypass at something like 18psi I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 5:35am
In your application of that pump I've not found any specifications; but they are simple to modify. That spring shown in Les's photo, (#11) is what actually sets the relief pressure, or opens the bypass as mentioned. I've seen those pumps relieve at 20psi, (shot) and I've seen them make in excess of 100psi using diesel fuel as the fluid medium. I've never seen them in a hydraulic fluid other than fueling application myself.
The red pump is from a 6V-92TA, the green pump from an 8V-71, and the yellow pump in back is from a 3-53. All are Detroit engines I currently own. The two front pumps are left hand, the yellow rear pump is right hand. You can ascertain this by looking at the venting ports facing up and are seen on the two front pumps. The relief valves are on the left with the front pumps, on the right with the yellow rear pump in the photo. The wrench on the right is one I bent up to access hidden fasteners and worked well.
I've seen you chasing the same thing over on FB and I've found technical questions are best handled over there unless gossiping about farm stuff which fits well on this site any longer. But that is just my opinion.
Both sites have their place however.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 8:21am
The 2-71 typically runs around 60 PSI fuel pressure. I have no idea what the requirements are for your application
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 10:36am
It would be helpful to know what PSI the system operated at, as well as flow.
I have never seen the pump AC used. I have replaced a pump in the wet clutch on a Cat 9u D6, it is smaller than the DD fuel pump. But no idea of flow or PSI it operated at.
I know of a late AC HD 11 ag cat the owner had a pump special built to replace the AC pump. This was 20 years ago and was 2000 to 3000 dollars. So adapting a similar pump looks to be a cheaper way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 11:51am
Thanks everyone for all the info. Im so close to getting this thing running. It seems crazy that something as simple as a pump is holding me up. You'd think there would be any easy replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 12:05pm
I did find some specs on the hydraulic pump for the HD6 steering clutches; it has two sections, one section for each side. It did not give a specification for the pressure but did state that "Hydraulicsystem pressure is non-adjustable; system is designed with proper "built-in" operating pressure to disengage steering clutches"."
The manual does state that each set of gears has 1.5 gallons per minute capacity @1200 rpm.
I would guess that if you found a pump capable of ~2+ GPM and started out at ~20 PSI you could turn up the pressure until it could cycle the clutch it should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 12:51pm
Re that double section steering pump for later HD6E tractors.
The main clutch pump bolts onto the rear of that behind cover 13, so it is in fact a triple section pump.
Master clutch oil pump is only a circulating lube pump. And oil pressure is only around 20 psi.  I know this because ive seen some late 40M series HD6 that had a clutch pressure gauge fitted in the dash.
Also the drive coupling used on all the pumps is the same 2 fingered 5/16 square coupling used on the GM, as that is what some of us have bought when the pump couplings wear out.   The triple section pumps can wear out the couplings if people run too heavier oil in the HD6E tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 1:37pm
Ahhh... now we are getting somewhere! Big smile
Thanks for the input Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 1:48pm
That sounds about right. Only 2 hoses, one going to filter for clutch and one from the clutch sump. I know i read in my manual that the filter or filter housing has a bypass at around 18 psi for cold or think oil. It takes a dextron 3 atf if I recall. Not just hydraulic oil. So in theory if a man could get a barnes style pump, if it would pump atf, to push about 20 psi then it should work...I think..lol..maybe
