HD5 rear axle seal |
Dobry Den Chip
Joined: 28 May 2026 Location: Newbury, Ohio Points: 11 |
Topic: HD5 rear axle sealPosted: 22 Jul 2026 at 8:32am |
I purchased new seals from general gear and am struggling to insert them with the rubber gasket staying in place. Any suggestions?
Les Kerf
Posted: 22 Jul 2026 at 2:31pm |
I had to contrive a contraption using a board and block of wood held up with a ratchet strap when I did the seals on my Son-in-law's HD5G several years ago. Sorry, I didn't take any pictures but with some ingenuity it isn't too hard to do. Best wishes
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 542 |
Posted: 28 Jul 2026 at 6:22pm |
Gasket gets glued in, can’t remember the particular glue. Will look over the weekend for what I used. Be sure to tighten the sprocket nut super tight, I think it was 1600 ft lbs.
