HD 11
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: HD 11
    Posted: 02 Mar 2026 at 5:01pm
Is it possible to buy sprockets for a HD11
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2026 at 10:23am
Should be able to find some...there are 2 different choices based on serial number.....do you know which one you are looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2026 at 1:19pm
No sir. I havent seen it in person yet. The guy that is selling it says the sprockets are still usable but will need changing soon. All this came up all of a sudden. Ive got 55 acres id like to clear to put cows on. Maybe a few acres tilled. Its got some wet spots so ive got to ask soil conservation if i can even do it
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2026 at 9:37am
Copy that....well if and when you get some pictures and post them we could tell which sprocket you need.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2026 at 7:42pm
...if the sprockets are that bad,how do you think the pins and bushings are let alone the rails?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2026 at 8:50am
Major Problem is will need to change All or None to make it any viable.  Several have gone to locating 955 or D6 Sprocket rings or Segments and then changing out Rollers and that means redrilling frames, Idler can be revamped to accept 6.91 Cat rails where those will then outlive the machine.  Are NO 7.0 pitch rails available US any longer.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 9 minutes ago at 5:39pm
Don't be discouraging; great fun and exercise to be had rolling track back on that's walked off.
That's All Folks!
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 23 minutes ago at 6:25pm
Yup. BTDT. Lots of quality family time to be had when that happens! Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 8 minutes ago at 6:40pm
Did often on the 7g until swapped rails from that donor.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 4 minutes ago at 4:44am
I've not had the good fortune to need to do it on anything that small. I remember well a TD-25B tractor doing that track walking bit that down in a pit in December, 1980. Getting it back together to replace track release seals back at the shop was an "ordeal" at best for a 20yo kid working by himself.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 minutes ago at 6:28am
Worst ever had was a D8 48A, rolled one rail off in a Dirt Recovery company site, as he was trying to roll that back on rolled other side off.  Had to roll BOTH back on to get out of the Hole as flood of 1984 was on the way!!  Used a Old Track Hoe also in pit for heavy drag work.
Tractor ended up on cribbing for Segments DuoCone seal assemblies, trucks both off and all rollers both idlers resealed both tensioners and replaced both rebound springs, EIGHTEEN DAYS!!!!  Bolts broke, had issues with anchor points wear, trucks ended at a weld/machine shop for three days of work.
Poor old machine had been neglected FOREVER, fairly certain were OE Rails.
