Guess I screwed it up |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33857 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Apr 2012 at 1:02pm |
Was doing a little grade work with a drag blade behind the 180D yesterday, could smell fuel then saw the dripping from the front seal area, pulled the dipstick and she was overfull by a lot. I just replaced the injection pump a month ago, been fine til now, guess I did roll the seal and it finally gave up. Oh well, time to change the oil anyway!
Edited by DMiller - 28 Apr 2012 at 1:02pm |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Well you got a good engine flush out of it anyway.
1957 WD45 dad's first AC
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Well, you will have to fix the seal, but more than likely you didn't ruin the engine in any way. Diesel fuel still has a lubrication factor to it. We always used to run about a quart of diesel fuel or more as needed in our Perkins power units the night before an oil change. For some reason a couple would carbon up real bad, and the oil would be too think to drain out, even on really short oil change intervals.
Still in use:
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5094 |
You apparently rolled the fuel side seal upon installation of injection pump. Bummer. Happens quite often. The important one is the tough one to get in too! Good luck, Ed.
I even had the little round pinchers to compress the seal and used STP on it, guess I will have to double check harder this turn, I did not use a mirror to verify last time. I do have a packing hook(dull tip) this time so if it does try to roll I can nudge it around to flat.
Seems the hard lessons stick harder/longer.
There is a chance you didn't mess up, if the pilot tube spun out.
Man, I hope it has not and it is just a seal.
Got to it today, I am getting faster at removing this pump, was the seal and I cut it when I installed it. Now just waiting on replacement to show in the mail.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24646 |
Sure hope you ordered two of them !! Not an insult,it's just nice to have a spare on the shelf..
And yes BTW I did order two full sets as a just in case.
