Groundhogs under concrete slab building |
Page <12 |
Author | ||
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34257 |
Get some used steel and bury it along the wall.
Sponsored Links | ||
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
An "old timer" told me that they are NOT happy with pieces of barbed wire in their "filled in" access hole
klinemar ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Michigan Points: 8047 |
Hydrated Lime in their hole works to move them out. The only problem is they dig a new hole somewhere else. I have used Cat Litter complete with Cat urine and feces . I would move on if someone dumped that in my hole! Best is Coni bear trap. Problem solved. Then mix some soupy redi mix concrete and fill the hole.
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
They got under our country church and knawed thru the porch floor. Minster loves to shoot. He sat outside and poped them of with his 22 mag. He asked us "Don't tell tell the gals".
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8436 |
For some reason this response got me thinking od Bugs and Elmer Fud! I think the wet cement does the whole project at one time. Just sayin! We are infested with them at our tractor show grounds buildings. They have shot 50 or more. They keep coming! Regards, Chris |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86125 |
I might start a business selling used cat litter... How much would you pay for a pound of chit ?
Steve you can try to sell used cat litter. Most cat owners would gladly give it away!
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1150 |
Pure cholorin bleach down the hole will work.
I have gotten rid of them and moles with a few of my old small engines. I had a ground hog dig under my shop floor. I used a gas appliance connector and stuck the end in the hole and sealed the opening with moist dirt. I filled the tank full and let the engine run till it was out of gas. Nothing ever came out of the hole and there haven’t been any new holes either. The same thing worked for moles. Gas exhaust line in the tunnel connected to a smoky engine equaled no more moles in the yard here.
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
Cat litter to me is a Bio Hazard. I'm surprised the government hasn't weaponized it.
That even tops changing a chitty diaper. My boy's when they were younger thought it would be fun to jack with dad by peeing in the litter box, it was in the bathroom. I told my wife then there is something wrong with that f...g cat. Found out later it was them. I had a skunk in an enclosed part of my shed. Took a couple of lengths of gutter downspouts and piped it into the shed and put it on my WD exhaust and let it run for a couple of hours. Throttle it up and choke it a few times. It worked. Burnt all the paint off the gutter for first 2'.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3563 |
Lou, I thought it was pronounced dye mo nite,
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
most all the ways told here are good ones...but...set up your vid camera and use tannerite!
modirt ![]() Orange Level Access ![]() ![]() Joined: 18 Jul 2018 Location: Missouri Points: 8346 |
House across the road from me had them dig under foundation. Owners called professional ADC guy and he set cage traps. Blocked the hole so only way out was into the cage. Caught 8 in a week. None since. A 220 conibear would do the same.....if legal AND if no other animals around that matter.
I told the wife to start collecting cat crap in a buck.. I took 2-3 pounds today and put in several mole runs in the yard and barn lot... Will see what happens !
Page <12 |
