Governor 190 gas
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Governor 190 gas
    Posted: 15 Aug 2025 at 7:29pm
On my uncle's gas 190 I can't get the governor adjusted. It goes from idle to airplane speed if you just touch the throttle. The linkage from the carb to governor arm is free and smooth. The linkage was too long by quite a bit. I adjusted it so the pin is a slip fit with the throttle lever open and the carberator throttle shaft wide open. I think that is correct. Starts fine and idles and like I said goes zoom with just a bump of the throttle lever. Any suggestions? Governor weights or internals?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 9:15pm
I've never had one of those governors fail internally. But, I think yours has.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2025 at 10:12pm
I was hoping you wouldn't say that.
Wink
I am a Russian Bot
