Gleaner L header on an L3? |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Topic: Gleaner L header on an L3?Posted: 17 Mar 2017 at 11:29pm |
Will a header for a L fit right on an L3? My uncles are going to be needing a pickup for their Canola this year, and I found a 13' header with a pickup that came off an L for $1,000. Seems cheap enough, but I was wondering if it would fit.
The same guy also has a 1980 L2 with a 24' header he is selling for $7K, so I'm thinking he must have used this other header and pickup on it as well.
MACK
Posted: 18 Mar 2017 at 7:41am |
I don't know of any reason it would not work. MACK
CrestonM
Posted: 18 Mar 2017 at 8:30am |
Ok thanks...I just thought since they made so many improvements over the L's to get to the L3's, they might have changed the feeder house mounting brackets some.
Jwmac7060
Posted: 18 Mar 2017 at 2:49pm |
It will hook up just fine
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 19 Mar 2017 at 11:29pm |
you will have to trim some on the vertical member on the RH side to make clearance for the feeder beater drive sprocket and hub.
Or find a wrecked 77+ L/M header and swap crossmembers. If the guy had been running it on a L2 allready, I bet any and all necessary trimming is allready done. |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
