Gleaner K2 corn head alignment problem
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner K2 corn head alignment problem
    Posted: 2 hours 52 minutes ago at 9:42pm
I purchased a '78 K2 Corn/Soybean Special a couple years ago, that came with a grain head. This spring I acquired a low profile black A330 corn header, from a gentleman who had used it on multiple K2's for his test plot business. I assumed these would be similar vintage and align.....I discovered that the sprocket on the cylinder drive shaft on the combine is about 1" off to align with the innermost sprocket on the corn header. Any advice?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 9 minutes ago at 11:25pm
You need the double 13 tooth sprocket on the thresher countershaft - will try to get pn tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 54 minutes ago at 11:40pm
A double sprocket was what I was suspecting... I've got parts books and manuals I've been researching- are both sprockets the same size- 13T? For a K2? I've got a parts book that shows an inner 13 tooth sprocket and an outer 25 tooth sprocket, for a K2.
Thanks!
This page was generated in 0.091 seconds.
