The unofficial Fl-50-24 forklift thread |
Jimmybeam01
Joined: 22 Sep 2021 Location: Boyd Wisconsin Points: 11 |
Topic: The unofficial Fl-50-24 forklift threadPosted: 23 Sep 2021 at 8:53am |
So I named this post this, cause there is limited info on this forklift specifically. Would like to help the fellas and myself by starting this thread. Having troubles nailing down good info on this Allis chalmers FL-50-24 LP lift truck.
I keep getting a overload code on my multi meter on the black wire that goes to the alt. Dives the am meter. I’m guessing it’s grounding out somewhere but it raises the question, is this forklift pos ground? Also trying to figure out what motor is in here, I think it’s a buda Here are some photos ![]() ![]() ![]() ![]()
Jimmybeam01
Posted: 23 Sep 2021 at 8:54am |
I couldn’t figure out how to rotate photos, if there is a moderator can you help turn them for people to view easily?
Jimmybeam01
Posted: 23 Sep 2021 at 9:53pm |
Anyone?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 24 Sep 2021 at 4:44am |
Check the wire from the coil to dist. Is it hooked to + or - at the coil?
Jim.ME
Posted: 24 Sep 2021 at 5:57am |
Could it be this one? AC G153 (Buda 4B-153)
Jimmybeam01
Posted: 24 Sep 2021 at 10:00pm |
I’ll have to check this out tomorrow
Jimmybeam01
Posted: 24 Sep 2021 at 10:02pm |
I tried opening the link but it doesn’t load. Just trying to find more parts, info, wiring all that stuff for mine. I’d like to restore it to its original condition
Jim.ME
Posted: 25 Sep 2021 at 6:59am |
It is a site that had several pictures of a G-153 you can compare to yours. Sorry, I don't know why it won't open for you, it works every time I try it.
Jimmybeam01
Posted: 25 Sep 2021 at 3:01pm |
![]() Here is how the coil is set up. - near dist |
Jim.ME
Posted: 25 Sep 2021 at 3:59pm |
To me yours looks like the one in the pictures I posted other than it is gas and yours is LP.
DiyDave
Posted: 25 Sep 2021 at 6:44pm |
If its set up as - to dist, its set up for neg ground. However, that don't necessarily mean its set up right...
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 25 Sep 2021 at 6:52pm |
Trying to understand why Three Wires on Pos. Side of coil?? Should be a Ign feed from Switch then Starter Bypass, Third one??
Jimmybeam01
Posted: 25 Sep 2021 at 7:15pm |
Ya who knows the maintenance guy that took care of this ol girl. Trying to slowly fix all these weird things and I’m tired of jumping it. But my biggest pet peeve is gauges not working. I know I can one wire it but I’d like to get it all hooked up as it was from factory
Jimmybeam01
Posted: 25 Sep 2021 at 8:13pm |
Also trying to find a hydraulic filter. And the bushings for the chain sprocket on the mast
Jimmybeam01
Posted: 26 Oct 2022 at 9:39am |
anyone have any wiring diagrams for a FL forklift? still struggling with this thing
Joined: 11 Sep 2009 Location: illinois Points: 90800 |
Posted: 26 Oct 2022 at 1:50pm |
cant see enough of the alternator to tell if it is an internal regulator or external regulator type... FL50 should be from the mid 1960s ?? Would be very UNCOMMON for a tractor at that time to have an alternator... normally they are generators..
Dont have a wire diagram, but they should be VERY basic in the ignition and charge systems... Amount of dash gauges would be the only unknown.. Wire diagram for a D10-12 might be worth looking at for an "idea" of how things were in the 1960s ........ I see service manuals on line that might have a diagram, but they are $75. or more.
PaulRoidt(WI)
Joined: 11 Sep 2009 Location: Montello WI Points: 137 |
Posted: 26 Oct 2022 at 3:47pm |
Our F4024 is positive ground. I suspect your has been changed to negative ground since it has been converted to and alternator. I had a bad coil wire recently that really made it a bear to get started.
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 26 Oct 2022 at 11:36pm |
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
BingoBob
Joined: 28 Nov 2021 Location: Brighton, MI Points: 6 |
Posted: 15 Jan 2023 at 5:03pm |
Try going to www.liberatedmanuals.com, put 'allischalmers forklift' in the search box and then look for a 'tech manual' for your lift.
BingoBob
Posted: 29 Jan 2023 at 5:29pm |
I know this is an old post but maybe you could still use this schematic. SorryI didn't realize I had this on my drive but here it is:
![]() Edited by BingoBob - 29 Jan 2023 at 5:31pm |
