ISO Head Gasket
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Topic: ISO Head Gasket
    Posted: 01 Feb 2017 at 7:16pm
Last winter/spring we rebuilt a 7020 engine. Everything seem to go well. The customer says it is now pushing water out the overflow when under load and also seen oil in the water, which was addressed by replacing the engine oil cooler, which didn't cure the oil in the water. With some inquiry, it been concluded the head gasket may be the problem due to the fiber flaking off. The gasket in the kit was the fiber style and seems like the best type is the metal clad type, which isn't available through Agco or after market sources. Would anyone know a source for this head gasket or possibly solution to correct this?
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:43pm
solid copper
phil
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 10:46am
I HAVE HAD GOOD LUCK WITH NAPA GASKET SETS.
 LINK: Head Sets
THIS IS THE PART NUMBER FOR THAT ENGINE: FEL-PRO  HS8289B
Edited by Acdiesel - 02 Feb 2017 at 10:47am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 12:58pm
I think you have other issues,  we install a lot of 301 head gaskets thru many sources w/o issue. It is an easy head to seal. Check out the sleeve stand out and head being true.
Edited by tbran - 02 Feb 2017 at 1:19pm
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 1:29pm
Ditto's on the NAPA head gskt. sets. Just finished a Nav. DT466 and it was a felpro head gskt. Dealer wanted almost 200 bucks more for their gskt. set. Good Luck, Mike
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 3:11pm
Im with TBran on the gasket issue. I saw some bad ones from High Cap a few years ago on some 426s but none on 301s. Did you have the head checked? Im wondering about a leaking injector sleeve?
Jim
