Allis chalmers 7000 Pulling Tractor |
Jm_hall_471 ![]() Bronze Level ![]() Joined: 27 Jun 2022 Location: Tennessee Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Jun 2022 at 7:03pm |
If you are pulling a allis 7000 do you remove the 1 2 3 power shift out of the transmission if you are pulling in light limited super stock. If so how is it done
Thank you for the help in advance |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
Light-Limited-Super Stock to me means over 1,000 HP, so yes, that clutch must go. A coupler needs to be fabricated to connect to whichever range you want...under drive-direct drive or overdrive. Approx 20% jump between each range.
Much appreciated
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8738 |
Welcome to the forum. We like to see pictures and hear about your orange tractors
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8368 |
Always heard the 7000 was a one of a kind with the Powershift setup it had- and they were based on a 200 tractor- so the powershift can be removed , interesting
All original Power Director tractors that were hydraulically activated were two-speeds, direct-drive (high) and 20% under-drive (low). The model 7000 tractor had a 20% over-drive added to the concept. The whole torque housing is completely different with this new design and the PTO is fully independent and 540/1000 RPM only. Amazingly, the length of the torque tube is still 39 inches, the same as previous models (180-185-190-200).
Is there any info on how to make a coupler of some sort for the powershift gears. Thanks
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Hey Doc , ever do any comparison with the gears between the 180 / 200 vs the 7000 as to a retrofit ? I noticed the 7000 do not use the bushings on the pinion...
You know, it's been since 1977 that I had my first maroon 7000 transmission apart. It had a bad pinion seal transferring oil one way or the other. I had my second one apart in the early 90's for reverse gear on the counter shaft having the teeth all chewed up from a heat treat issue. They have been that good !! Two 7000 transmissions in 40 plus years !! So, no I did not compare parts to the 180-200 transmissions, but I know the gears are all wider and I'm thinking the inner diameters may be larger too. The width would be the deal breaker in the end I think.
zero61 ![]() Bronze Level ![]() Joined: 21 Aug 2022 Location: Paris Illinois Points: 23 |
I’ve been running a 1980 black belly for the last eight 8 years I’ve done a lot of changing inside of my transmission tried to upload a picture but it wouldn’t
If I remember, this one has a 5.9 Cummins which does a great job !
Yep 5.9
Blew up 2 301 motors |
Welcome to the forum. Thanks for sharing
We are lost at the transmission. How did you build the transmission to hold up to the power?
I have no problems sharing what I’ve done to my tractor. send me an email at zero61puller@gmail.com
And I’ll shoot you my phone number. and it’s a whole lot easier to send pictures and tell you how I did it on phone |
Or go to Facebook
Look up Robert Clark Or tuff times pullin team Get me that way!! Sending pics on here is impossible on a phone… |
I have no idea what JM hall is trying to do, but I am used to LLSS tractors running road gear, which is direct drive. If you want to go faster than that, then you are getting into the custom gear making area. A true model 7000 drive line would have room for an over-drive box right under your feet where the Power Shift clutch assembly was. Road gear in the tranny with an overdrive speed-up ahead of it.
Yes!! A 7000 is 27.885 to 1. Strait thru in 4th.
I had two gears made on input and runs low side. 25.4 to 1 is result. Only have 1 gear but hey I’m a do it yourselfer low budget puller. |
7000, 200, 190XT all the same ratio in road gear.....27.88 to 1.
I’ll do my damned to try and put on here with my granddaughter help to show how I done it..
Lot of 7000 to use as pullers |
Wonder what chassis Bernie Platz has under him ? Its 7000 sheet metal and I believe a 426 with multiple turbos - I think this dont know for sure ; curious if its a 7000 driveline ?
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8665 |
It was a 190 rear-end 2 years ago
Power through trans. is no problem, gears will hold. Weakest point is ring gear moving away from pinion. This can easily be fixed by a girdle around right bearing housing and reinforce out side of bearing housing. MACK
