Disc brakes |
Acllss puller ![]() Bronze Level ![]() Joined: 02 Oct 2013 Location: Ny Points: 181 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Mar 2016 at 9:09pm |
What are you guys using for a hubs to use as disc brakes on a190 rear end and how big of a diameter rotor can be used. Any ideas would be helpful thanks.I was thinking of machining the factory hub off then drilling it for whatever rotor we use.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22101 |
That would be OK fine. Use the largest diameter you can for best results.
Larry W. ![]() Silver Level ![]() Joined: 07 Nov 2010 Location: Luck, WI Points: 282 |
I just saw a settup on a 190 today, they utilized crower clutch discs for the rotors , worked really well, and a very successful tractor.
bsallis180 ![]() Silver Level ![]() Joined: 29 Jul 2013 Location: Pennsylvania Points: 209 |
http://www.allischalmers.com/forum/forum_posts.asp?TID=67825&title=190-brakes
Brett did you post something or pics didn't come through
Just a link of a old thred " copy and paste" Not sure how to make it a "true" link
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
I asked about this that was the post from the past I used the old inner hub as a pattern and made an adapter to put ford Tauris rooters and calipers on used summit master cylinders they will lock the wheels up instantly
the only draw back is I have no parking brake
Bob C IL ![]() Orange Level ![]() Joined: 25 Sep 2009 Location: Paris IL Points: 369 |
if I could get pics to send off phone I'd send my homemade setup and works great!!
I could text or email if someone wants to post em
It let me do one pic only but it's Harley rotor and 4 piston caliper from a road glide and master cylinders from jegs
Edited by Bob C IL - 08 Mar 2016 at 11:47am |
if I do it again I'm going to use international rotors mounted to the back of my wheel hub hopefully I will have a better feel as the current set up has induction factor
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
You could put a microlock in to have a park brake, couldn't you?
AaronSEIA |
I used rooters from VW rabbit bolted to 190 disc splines. MACK
