Finally got that old Horizontal mill home.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Finally got that old Horizontal mill home.
    Posted: 30 Mar 2023 at 7:45pm
Went and picked it up tonight.
I have it close to its permanent spot. I need a power feed belt and to figure out the power feed then I can back it in a little more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 9:16pm
DANG Thad............. your about ready to start a Machine Shop !!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 9:00pm
Looks good! I was looking into flat belts for the power feed on my universal grinder and was mostly coming up with Megadyne stuff unless I want to risk some no name Amazon type brand. The main drive belt for the spindle on mine is a Megadyne T150, I think, in whatever length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2023 at 9:34pm
I need to look in to that. My lathe is flat belt and a drill press along with this mill. This mill belt is really nice but much too narrow.
It works but I don’t think it would handle a deep cut without slipping.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 9:00pm
An automotive serpentine belt will frequently do the job well.  Shortening the serp to fit can be a little bit of a challenge, but cut it at an angle, and glue it with a backing on the non-running side, and it'll work... or put an additional idler in there to tie up more slack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 10:03pm
I bought a belt the right length.. No cutting.. Shortest belts are about 44 inches, but you normally need quite a bit longer than that.... Widest is about 1-3/8 ... the grooves grab well on the flat pulley..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2023 at 10:05pm
