Speaking of Welders n such
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Speaking of Welders n such
    Posted: 16 Dec 2023 at 7:29pm
I need to buy some Argon mix.
This has me wondering about oxygen, acetylene and argon mix prices. Has anyone bought any recently?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 8:14pm
Last tank I picked up was DOUBLE what paid two years prior.  That was LAST Spring, oughta be about insane now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 8:37pm
That’s what I figured.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 8:53pm
What do you weld with the ARGON ?   You doing aluminum ?
On standard steel, i just use CO2 ... Cheaper and works great.. Doing that for 25 years.
Codger View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 9:58pm
I usually use C25 mix which is 75% Argon and 25% CO2. Lot less spatter and it produces a better wetting action at the toes or edges of the weld puddle. Straight argon is for aluminum welding only in my usage.
That's All Folks!
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2023 at 10:35pm
 Ditto what Steve says, Thad. I used to use the 75/25 Argon mix til they wanted me to give them the numbers to my credit card,,,,,LOL I had a fire extenguisher from work tested by and repurposed  by AirGas for straight CO2 which is MUCH cheaper and works great as an all purpose sheilding gas,,,,
 I go even farther and now use propane gas instead of acetalene on my cutting torch set,,, works great with the correct tip,,,ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 4:58am
I’ve always used 75/25 mix for mild steel.
If I can save a $ I’ll try co2.
Does it use the same tank and regulator?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 7:35am
I run straight argon when tig welding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 8:51am
Thad..........., the CO2 runs at a lower pressure so normally the tanks are MARKED and remain that way for a SPECIFIC GAS.. Since your going to a REDUCED pressure, the FILLER may change the TAG and fill with CO2... ask them.... The regulator can also be used, but the fittings on the bottle / hose are different, (so you would need a new adaptor / fitting to go on the bottle..... assuming the FILLER will change the fitting to a CO2 type.)... Possibly they can remark the bottle and use the same fittings ???  That would be entirely up to the filler.
My son got a Wire feed bottle with CO2 and it would not FIT our hose.. I bought an adaptor for it... I think they had a Argon/mix bottle and remarked it for straight CO2 and left the Argon fitting on it........ thats what you need.
Edited by steve(ill) - 17 Dec 2023 at 8:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 9:05am
Have ran the Argon/CO2 blend here as seems as noted less spatter, and with shop doors open less shield drifting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 9:18am
Here is a photo off the internet.. I cant give a PERSONAL opinion, since i have never used the MIX.... I have used CO2 for 25 years..
Edited by steve(ill) - 17 Dec 2023 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2023 at 9:37am
75/25 is called 'Autogas' or something similar. Used for thin tin welding like doors,fenders, etc.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2023 at 3:55pm
Have used 75/25 for years , tried some straight CO2 and spatter was problem .
I have couple old CO2 fire bottles I keep filled with other gas , extra Oxygen and straight Argon , I made up a jumper hose to fill them from new bottles when I get one .
 Acetylene is hard to get , local welding shop does not handle it , MAPP gas now only.
I have been using Propane for cutting and heating after changing tips on cutting and buying a Propane rosebud .
 Propane will work for brazing but somewhat slower on gas welding , Acetylene cost is out of site now but as I have 3 empty tanks I might get one filled just for gas welding .
 I have 322 cu ft Argon / Co2 tanks and oxygen tanks and a few 122 cu ft tanks also , somehow I seem to have acquired around 15 different certified tanks over the years along with my  cheater Co2 tanks . Couple Oxygen 322 tanks also
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 8:27am
 Hey Coke,,,,You know,, the supplier also told me some time back that acetylene was getting real hard for them to get so they started raising the price to consumers,,,,sound familier,,,?LOL   I finally quit that circle and went with propane and the correct tips and I can fill the bottle from my big house tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2023 at 8:43am
Acetylene is formed by Calcium Carbide placed in water, is a mined stone and getting more difficult to find in quantity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2023 at 4:41pm
Big problem is Acetylene is Unstable gas and inside the bottles they use Acetone to absorb the Acetylene to make it stable for use . The bottles have a core material in them to hold the gas in suspension . Mississippi Welding here does not handle it now - is where my son gets his supplies from . They recertified my tanks and marked them as customer owned so he has to exchange his own tanks and they charge for the fill - rather than full bottle exchange .
 I see Fleet Farm does Acetylene bottle fill or exchange here in Hudson WI .
