7060 hydraulics
spencefarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hydraulics
    Posted: 08 Dec 2015 at 4:37pm
So I have a 7060 and when I was field cultivating last month all of a sudden hydraulic oil started spraying from the back of the tractor. I lost all pressure and I can't find the leak. So I need some advice....
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 4:41pm
Refill and find another set of eyes. Took my dad and I 20 minutes to find one on his combine a couple years ago.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote spencefarm Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 4:43pm
The pump had been whining a bit before that. Is it probably just a busted line or could it be the pump went out?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2015 at 11:22pm
Hyd. pump is not on back of tractor. Line most likely.  MACK
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2015 at 6:06am
Theres a steel line that vibrates and wears through the clamp on the left side ,cant remember which one but i have welded mine twice back in the eightys, it is now hydrulic hose instead and hasnt given any trouble since.
This page was generated in 0.107 seconds.
