locking fuel cap |
allis converted ![]() Bronze Level ![]() ![]() Joined: 10 Jun 2011 Location: opolis, KS Points: 40 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jun 2011 at 9:50pm |
Hello does any one know where I can find a locking fuel cap for a 190xt? I just filled it up and somehow over night it used over forty gallons magically. The local parts guys keep scratching there heads trying to cross it over to something else.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Sounds like you need a junk yard dog, but don't we all. It don't say much for our society now days.
Edited by CTuckerNWIL - 24 Jun 2011 at 9:56pm |
I'd have better luck chaining the old lady out side than the lazy old coon dog!
bump
acwdwcman ![]() Orange Level ![]() ![]() Joined: 16 Oct 2010 Location: palmyra, il Points: 1075 |
well just throw the old lady out side and bring the allis inside.. lol their problem solved
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Bee ![]() Orange Level ![]() Joined: 14 Jun 2010 Location: NC Points: 201 |
If you do lock the cap can they just disconnect the fuel line and drain it anyways?
Bob, North Carolina
1949 B |
Your best bet is fuel it only as you need. Yes, it's good to fill it when you're done for the day, but if some low life is going to steal the fuel, doesn't do your wallet much good. Just have to drain any water off more often.
My neighbor drained the tank on his 4020 unhooked the fuel line and filled the tank with water it was pretty easy to figure out who was stealing his fuel. He tried a locking cap first but a slide hammer made short work of that.
amac ![]() Silver Level ![]() Joined: 11 Nov 2010 Location: Kalona, IA Points: 251 |
its too much work to go into the top of the tank and then siphon it out. its alot easier to unscrew a fuel line and let it run out. that's what they do to our tractors. It doesn't even help to padlock the door to the building we keep them in.
This the second time they got me, last winter someone packed 45 gallons off in cans 3/8 of a mile walk from the nearest road in 18" of snow if they needed it that bad I would have just gave them some all they had to do was ask.
If the tank isn't full, they can't steal what isn't there...
Protrucker ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Broome Cnty,NY Points: 718 |
It sounds to me like a midnight shift with a 12 ga is in order. Either that or run a hidden wire from your hottest constant charge fence charger to the tractor. The rubber tires won't ground it out, but wait till they try to get your gas then!
Edited by Protrucker - 25 Jun 2011 at 1:03pm |
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Not so sure on the 12, but I do know a lot of people are using those trail cameras. Put them someplace where they can't be seen, but close enough to have good resolution of who is doing the work. Quick call to the local police with the pictures should help fix the problem.
AaronSEIA
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
The locking cap probably won't vent either so the tractor will only run in 15 minute bursts with it in place.
Gerald J. |
oh and the ambulance
for them!!!
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
I'd set up the trail-cam, but also set up a motion sensor (just the sensor) on a box about waist-high, looking towards the tractor, kinda upwards... and hook it up to a small light shining towards the house. When you see the light go on, it's time to take a walk with the Mossberg and cellphone.
Rawleigh ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
On my Case 930 I got one from Advance Auto. Take your cap in and have them match it. They are pretty standard. I was more worried about someone putting something in the tank than taking it out.
Okiejohn ![]() Silver Level ![]() ![]() Joined: 18 Apr 2011 Location: Orlando, OK Points: 99 |
I'd put out a BIG sign outside the place where my tractor is, saying Warning, to whoever is taking my fuel. I am sitting out here with a loaded 12 gauge shotgun, loaded with 00 buck on some nights. YOU PICK THE NIGHT YOU FEEL LUCKY!
Be sure you are right, then go ahead.--Davy Crockett
Well some one is sore today last night after I finished bush hogging I parked the tractor next to our sewage lagoon and wrapped about six runns of barb wire around it and then went to the loader end about dark and tied my coon hound up then I sat on my porch with my browning humpback, about eleven thirty I heard people talking they had made it all the way to the fuel tank and I fired two shots in the air then the dog started barking one of them got caught in the wire the other one tried to run and fell in the sewage lagoon then he must have climbed out and gotten hung up in the fence on the RR ride of way. This morning I found a ripped pair of jeans with some blood on them the dog was chewing on it, I walked the tracks and found a muddy cowboy boot. Hopefully they won't be back again.
