HD6B Identification |
youngbuck_oldiron ![]() Bronze Level ![]() ![]() Joined: 29 Dec 2022 Location: ohio Points: 10 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Dec 2022 at 4:16pm |
I am trying to confirm the year that my HD6B as manufactured to obtain the service manuals for it and the parts catalog. I was told that this was a '64, however the serial number on the tag indicates that it is much earlier than that.
The tag on the instrument panel was highly corroded and barely readable. I have photos of the tag before I cleaned it off with steel wool to verify the serial number. Tractor: 6-9550 Engine :6-9559 Engine Tag: Instrument Panel Tag:
HD6 Merv ![]() Silver Level Access ![]() ![]() Joined: 03 Aug 2010 Location: New Zealand Points: 498 |
your HD6B is 1958 build with the HD344 Buda design, indirect injection engine
tits tyres and tracks
they all cost you money |
Thank you very much. This is going to be a long process. I know that i will need a hydraulic pump and mount bracket, starter solenoid needs to be rebuilt, and steering and brakes at the minimum.
![]() Here is the picture of it. Been sitting for 10 years now. tracks and throw out bearing are still free, moved it this year with a Cat 420.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2245 |
Those track pads have sure seen some use. Looks like a neat project. Does the engine turn over? I have kicked around an HD-11 project that is close to me, but I pretty well got scared off by the unavailability of engine parts for the old AC/Buda engines in that era of crawlers.
200Tom1 ![]() Orange Level ![]() ![]() Joined: 03 Jun 2019 Location: Iowa Points: 1232 |
You might as well tackle the job, its just nuts and bolts.
Motor spins freely. Removed the fuel filters and drained the old diesel out. All lines are not blocked. Working on rebuilding the starter now, the one terminal melted, new battery cables being installed and electric system overhaul.
