Homemade Creations?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Homemade Creations?
    Posted: 21 Jan 2011 at 9:33am
What are some of the things you have made that is one of a kind.Things that you have modofied.Tell us or show us your homemade creations!
Thought there mite be some great ideas in your shops or equipment.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 10:04am
Built this firewood processor two years ago. Started out with our old home built splitter, a military trailer, a Freeman manure loader and a hercules power unit and ened up with this. Saw is mechanicaly powered and clutched with an ordinary 12V mower clutch. Saw dog and saw lift is by air. WIth about 45 GPM of hydraulics, the saw drive and the air compressor the little IXBL5 Herc gets a work out. We can process about a cord per hour as it is but if I was to add about 40 HP  production would easily double.  We can process up to 24" diameter wood and the log lift allows us to chain saw the big stuff and still use the splitter.
Kinda ugly but I dont intend to take it out on a date.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 10:07am
    Hey! what do you mean ugly? It's beautiful, I'd take it out.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 11:06am
Quite a contraption there butch.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 12:50pm
Dad was storing our old HO scale train stuff for YEARS, and he wanted it gone.  I said I would take it to my house, but wasn't sure how to set up an area that was 'minimum' effort to store.  Used an old boat winch, and 4 cables to suspend this 8' x 8' table in my garage.  Put 15" pvc pipes as 'stops' in the up position, as I built this large grain elevator that is also stored on it.  It comes down to 36" for use.
Greg Kroeker
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 3:21pm
Butch, can you send me a copy of the service manual for the splitter? I am sure that you have one?  RIGHT!  LOL  what works, works!
Dave in PA
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:09pm
uploads/27/Lift_005.JPG
Boat lift built from scratch, using new and old steel, powered by 2000# 12v atv winch.
uploads/27/Lift_002.JPG
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:33pm
All I have is this trailer, nothing fancy,
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 6:40pm
Great looking dump trailer.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 7:10pm
You sir are my newest hero.
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:32pm
Well this is one of many things I've built.....Dad and I's Hog Cooker....He paid for it, and I built it haha
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:36pm
The frame paint didnt hold up that well to the oven cleaner we use to clean after cooking but I dont much care...I just want it clean when done being used....tractor supply axle, 200 gallon commercial hot water heater, some odds and ends of GM engine parts(455 cam, 1.94 SBC valves, Big Block Olds Rods, stainless grates from a commercial freezer at my buddies junk yard, gate hinges, wheels I found next to a dumpster....and this thing is TOUGH...came unhooked when a buddy hooked it to my truck....rolled 3 times, wiped out a guard rail and all I had to do was loosen the U bolts and put the axle back to center, bend the slide out tray back to straight, and it was good to go again!
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 9:26pm
I have a deer stand.
Mike(NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(NC) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:40am
_popupControl(); Benny,  Nice job on the cooker.  I've found if you just let it cool after cooking the oils and grease from the hog keep the grill from rusting.  Looks like you can slide the grill out to turn the hog, but you can also use a pressure washer to clean it.  That'll save the paint.  I usually fire mine to burn off the grill then pressure wash it if the heat don't fully clean it.  It works like the self-cleaning ovens.
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:04am
Built fold up sprayer for my zero turn mower. Uses old fashioned dimmer switch to turn on and off 12v pump. Sprays 12' strip. Makes small yards really a breeze.
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:06am
Another look.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:08am
Last Look
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:18am
You guys come up with some neat stuff keep them comming
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:26am
My Avatar. And a frame boom for my G, that many of you have seen. My picture posting has gone from bad to worse.
Dusty
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 9:52am
Benny, pig cooker looks great! Made me think of our cooker we made 3 years ago.
Built on a jet ski trailer, with propane tank, and home made fire box.
We have done ribs, chicken, turkeys, brisket, pork loin, burgers, some fish, whole hogs, and this whitetail deer in the picture. Definetly worth building!
Fire box also doubles great to cook breakfast on, for the early morning cooks!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 11:24am
Too numerous to mention, and most of 'em are modifications or attachments to machines, but here's two examples from-ground-up...
This is a rotary phase converter- powered by 240v single-phase, it puts out 230v three-phase to test machine tools and other 3-phase equipment.
This is a crude mobile hoisting machine, wide enough to straddle a common tandem-axle utility trailer.  The overhead beam is just at 9', so lift height is limited, but it WILL roll under my current overhead doors.  Has a pintle-ring up front, I shuffle it around with the 3-point I made for my D-17.  It will lift and move my 10,000lb Cinci #3 vertical milling machine... but more comfortable around 5000lbs.
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 11:54am
So, I'm thinkin we should all live in the same town somewhere so we can use each others stuff...
Bob, North Carolina
1949 B
This page was generated in 0.152 seconds.
